FS A ton of random (nice quality) drivers for DIY
UPDATE: I have one single Peerless 831773 left. (Still have 3 of the 831791 drivers, tho)
Also offering the following:
Very nice Acoustic Research mid-woofers to the mix. These were used on the Classic 18 and Classic 26 models in an MTMW configuration and WMTMW configuration, respectively. They are brand new old stock drivers and in great condition. Very well made. They use a 5.5" poly cone and rubber surround.
AR Part number 1210150-5. I have multiple pairs.
Asking $50/pr shipped. (This is about half of what they usually go for)
Great for DIY or replacement parts.
Example of the Classic 26 using these mids
UPDATE:
Adding to the list. Peerless 5-1/4" midwoofers. Part number 850442. They are shielded, poly cone and rubber surround. New old stock, never installed.
I ran them through a box calc software and they looked good for a small ported enclosure. I plan to keep a couple for myself for a small bookshelf project, or an MTM project which is what I think they were ideal for based on the low SPL.
But I have multiple pairs and don't need them all.
$50/pr shipped. Specs are below. Make offer for multiples. (Like if you need 10, just ask cuz I have them!)
Fs = 67.96 Hz
Re = 6.45 ohm
Piston dia = 101.6 mm
Zmax = 35.21 ohm
Qms = 2.989
Qes = 0.670
Qts = 0.547
Vas =4.82 liters
Le = .294 mH @ 10 kHz
SPL = 85.45 db 1w/1m
UPDATE:
The Advent 99-20240 tweeters have all sold.
The Advent 99-20107 tweeter has sold.
The Peerless 831773 woofers have all sold.
I have one pair left of the Advent 99-20167 tweeters.
UPDATE 1: I only have two pair of the Advent 85000017 Legacy, Laureate tweeters left. ($40/pr shipped)
UPDATE 2: I only have one pair (and one stray) of the Minebea/MNB/Onkyo semi-horn loaded tweeters left. These are the same tweeters used by AR for the XP series, as well as by Sjofn on "The Clue"
($50 for all three, shipped)
UPDATE: All of the Advent 85000017 tweeters have sold.
The MCM and Fostex woofers have also sold.
I have a pair of Dayton 3" full range mid-woofers. Model RS75-4. They are as close to new as possible. I used them to test out a little TL enclosure and then never used them for anything else. Would be great as a mid-range in a 3-way where they cover a wide frequency spectrum (150-10kHz).
$25 for the pair, shipped. (1/2 off retail price)
Specs here:
Dayton Audio RS75-4 3" Reference Full-Range Driver 4 Ohm
NEW PRICE
Lowering the price on these 10" woofers to $80/pr + shipping
And adding some more pics. I have about 6 pairs left.
Hi all!
Adding an item or two to this list.
AR 10" shielded woofers. Poly cones. Foam surrounds are in excellent shape. Great for use as a powered subwoofer. Relatively low sensitivity of around 87 dB. Shielded.
Here are the measured specs (YMMV)::
Fs = 30.95 Hz
Qms = 3.277
Vas = 68.49 ltrs (2.419 cu ft)
n0 = .26%
Mms = 64.5 grams
Re = 3.87 ohms
SPL = 86.31 db (1w/1m)
Piston Diameter = 209.6 mm
Zmax = 21.13 ohms
Qts = .601
Le = .362 mH
These speakers can be found in several of AR's later series including the PS, S, HO, and AW Series. They are ideal for a sealed enclosure of approximately 1.8 cu ft. But they are versatile and I have run simulations with ported enclosures too.
For you distributed bass or DIY guys, these would make nice bottom end drivers with a low <200 Hz crossover point.
$125/pr shipped to your door. I have multiple pairs available.
Still have 6 of these 10" woofers left. I am using two in an old KLH enclosure and they sound very nice. They like large ported boxes.
Make me an offer for all 6!?!
Hi all!
Fs = 30.95 Hz
Qms = 3.277
n0 = .26%
Mms = 64.5 grams
Re = 3.87 ohms
Zmax = 21.13 ohms
Qts = .601
Le = .362 mH
