Joined 2018
Hello, DIY volks,
I updated FreeDSP Catamatan A/B board and schematic design. A new feature is automatic DSP firmware reload on the transition of A/B program switching. The reset button is not required anymore!
JLPCB's PCBA information is also updated.
[FreeDSP Project Git-Hub LINK]
https://github.com/freeDSP/FreeDSP_Catamaran_AB
Designing Pleasure
CyberPit
Designing Pleasure
CyberPit
Hi Pit Great work 👍. I have a question is it possible give I2s input to "free DSP board". like from raspberry pi I2s out to I2s input to "free DSP board". is it possible.
Love this project.
Love this project.
Joined 2018
smagtech-San,
Thank you for your response.
According to those reasons, FreeDSP Catamaran is specially focused on Analog I/O Application design as you can see.
Following few weeks, I will release the design FreeDSP OCTAVIA. It has Raspberry-Pi slot, USB, Optical/Coax S/PDIF, and analog input. 8 channels UNBAL/DIFF/BAL output feature. If you want to insert Raspberry-pi anyway, please have a look at that thread.
CyberPit
Technically some limits exist, those belong to the I2S I/O limits, and missing the sampling rare conversion block.I have a question is it possible give I2s input to "free DSP board". like from raspberry pi I2s out to I2s input to "free DSP board". is it possible.
- The Sampling rate should be the same as interlinking and processing DSP's fs.
- ADAU1701 doesn't have ASRC
CyberPit
Thank you Pit for quick answer. i will be waiting for " FreeDSP OCTAVIA ". i have a idea of controlling eeprom from Arduino so even more epprom ic. also volume control from digital potentiometer like MCP42010 Ic. with graphic display. MCP42010 has 2 10k digital potentiometer so we can control left and right volume. what do you think Pit.
Joined 2018
Hi smagtech-San,
Additional CPU control enables various attractive features as you mentioned and more. The board debugging will be a little bit difficult but it is not a matter for you.
I do not recommend using MCP42010 for the Master output volume following points...
From the MCP41XXX/42XXX datasheet says
CyberPit
- FIGURE 2-23: 10 kΩ Wiper Resistance vs. Voltage. indicates non-linear characteristics will make distortion in the biased AC/Audio applications.
- FIGURE 2-17: Digital Feed through vs. Time indicates a big click on a changing the gain. (>100mV)
- The liner curve (called as "B" curve) is very few steps of small volume control.
- Low PSRR will be a critical power supply requirement.
CyberPit
