FM MPX filter
I'm working on an FM tuner/MPX decoder design, and I'm trying to figure out how to design the audio output filters.
I found a schematic in the LA3410 MPX chip datasheet, but when I simulated it in PSpice, I found out it wasn't that good... Here's a frequency plot:
http://stiftsbogtrykkeriet.dk/~mcs/MPXFilter.gif
Not a lot of attenuation at 19kHz and -3dB somewhere around 13kHz.
The next thing I tried was "expanding" that filter with some extra sections. That produced this result:
http://stiftsbogtrykkeriet.dk/~mcs/F4V10.gif
Good attenuation of 19kHz and above junk, but some ripple in the audio band. Here's a close-up of the 1-50kHz range:
http://stiftsbogtrykkeriet.dk/~mcs/Not_nice.gif
To get a nicer looking curve I tried calculating a standard low-pass filter (6th order Linkwitz-Riley at 25kHz in this case), and then I added some caps accross the coils to create notches. This is the result I got from that:
http://stiftsbogtrykkeriet.dk/~mcs/Nice.gif
Looks very nice in the audio band, but the -3dB point has moved lower, and the 19kHz and above attenuation isn't as good.
So which filter would actually work best and sound best?
I have looked at some Toko datasheets for MPX filters also. They have about 25-30dB attenuation at 19kHz, and some of them higher at 38kHz. But I have no idea what circuit they use. Would they be better, or would a DIY filter with good quality parts (rather than ceramic chip caps) be a better idea?
If anybody has suggestions or experience in this field I would like to hear about it :)
Best regards,
Mikkel C. Simonsen
Toko uses tapped inductors in the mpx filter
I often wondered about forgoing the deemphasis filter untill the 19KHz filter had been finalised it is quite probable a deep filter would do much of the deemphasis by itself. Also agree with above - pilot tone cancellation should always be first port of call. Thinking about it, a well designed LPF should deal with all admirably don't forget 38KHz switching artefacts also.....
The pilot is down 20dB from 100% modulation already, de-emphasis would take it down another 20+ dB, a bit of cancellation and you're done. Anything below 60dB would be into the noise floor. A high-quality multi-pole LPF should not be necessary, certainly not desirable either. 38kHz artifacts are all above 38kHz, starting at 3rd harmonic, so just not an issue.
I've never seen a LPF pilot filter in a receiver. Pilot cancellation, all the time.
