Most End up Lying on the Floor
Happy new year L.C.
True
For all of you guys who burn your modules....
Please write step by step what's wrong with these....
I want to avoid that issues when I'll begin to power them.
Thx.
Thx.
Well i have no correct answer on what happened, maybe i will leave that to Andrey to clarify.
All i know that i'm waiting for the new updated modules 🙂
We are many, and we are waiting for long, loooong time
Hi!
My strong suggestion is to never ever play with whatever sources connected to your amplifier powered ON.
Power OFF your amplifier mandatory before playing with preamp, dac etc connectors/cables/wires.
Double check any bad connection possible issue on the input side of the modules.
I fried one module because of a bad cable connector on my preamp side, whilst amplifier ON.
Beside this, my amplifier has been working all day everyday of past year ..... best sound possible with my 3 way floorstanding speakers.
Good luck
Jmk
Thx.
Don't short-circuit it while adjusting
I think only XLR connections if possible.
And if you can afford it, double mono or mono blocks setup with symmetrical preamp and electrically separated channels dac. It is really worth it.
Jmk
Be aware of oscillations. In one setup they were perfectly stable. In another setup they were very "eager" to oscillate. Monitor with your scope on the outputs!
Well i think i hold the record for the most burned modules here.
Till this day i have burned i believe 20 of them, well half of them two or three times. Dont keep track of that.
And i can say half of them were burned during adjustment, and half of them burned during powering on, but i believe the cause is the input stage.
For now i have 8 of them burned, 6 of them died in my 6 channel black beast the same way as last time. I was tuning my active crossover all morning, changing cards and all was good. Every time when i did something i had the amp powered down.
And one last change was the final. Powered it on, load of distortion from speakers,and they all died, even when they are not connected between.
Well now when Andrey will change them to new ones i will build separate dual mono's in separate cases and will use them only on special occasions.
Still the best amp's i ever heard. and i do have access to some pretty good gear.
I have made 10 moduls and only 2 off them got problems with the rl at the output. None is totally burned.
I dont say that the module design or something was the fault, some of them was my error some of them gear error. The only thing i can say that they are really sensitive. Ether way i have enjoyed the for i believe two years or more. With couple months of fixing between them.
And i believe i will enjoy them again, just have to wait for the new ones, and i need to build an amp with the L ones, because i still have 6 of them.
Try 0.1 ohm in series with output. I have made a four channel and a 2 channel for a friend and no problems. Just take care with where to place cables and use good screened and solid Connections.
- Vendor's Bazaar
- First One - mosFET amplifier module
