Tibi,
Any idea how much longer till my order ships?
Next week another 15 shiga will be shipped. I´ll do my best to have yours shipped in this batch. 🙂
Regards,
Tibi
I got the first of my 2 fully built shiga hooked up tonight.
First impressions: very positive indeed, excellent sound considering that it's just thrown together at the moment.
Me and the little connectors didn't get on too well, I will probably solder the motor wiring directly I think. Other thing is that it seems a little more picky about the cds that the jvc shiga. Playback is perfect so far on perfect discs, but I have skips and toc fails on more scratched ones.
I took a short video: https://www.youtube.com/watch?v=5LJ6oLDJs9M&feature=youtube_gdata_player
Thanks tibi! The work of the chassis now is next.
Fran
Fran
Instructions are all on tibi site - primaries to suit your voltage, centre tap on the tx secondary to the centre of the connector on the power board, other ends of the secondaries to the other sides of the connector.
Something else for other builders to watch out for: make sure that you fit the motor cable the correct way around. If you fit the connectors first to one end of the 6 way ribbon, then the connector at the other end needs to be "upside down" so that SP+, SP-, SL+ SL- and so on connect the correct way around. Just watch it when you are putting the cable together.
Fran
Fran
For those interested to build Shiga from scratch we have added on sale a mini kit which contain all critical parts to build Shiga.
Trafo, CD mechanic and other passive parts can be purchased from various sources, so we focused only on the parts which are unobtainable or very hard to find elsewhere.
- PCB boards for Shiga and Remote
- IC set LA9242M, LC78601RE, LA6541
- transistor set 2SA608NF, 2SB764E, 2SA1342,
- IR remote cipset SC7461-103
- Vicol-Audio custom multiplexed LCD
- Citizen CSA-309 crystal.
This contain worldwide shipping and is no need to add shipping to your order.
Also starting with 15. November we reopen webshop for 50 ready mounted and tested Shiga boards.
Regards,
Tibi
Regards,
Tibi
Documentation was updated and moved to gdocs.
https://docs.google.com/document/d/1vlabZc_1If3x12ox2A5ECZxC0HLGnuOWdM-j9X4b7Q0/edit
I´ll update the website as well.
Regards,
Tibi
Regards,
Tibi
Tibi the link points to an empty document
Thanks for observation.
Have corrected, please confirm if it´s OK.
Thanks & Regards,
Tibi
The connectors that came with the kit are small - and these awkward thums don't make it any easier!! I found this little video on youtube and it makes the process of soldering them much easier (I'm guessing most here won't have the proper crimping tool). I went and soldered up the second set tonight in 1/4 the time with perfect success. I think the key is that you only strip a tiny amount (2mm) of the end of the wire.
https://www.youtube.com/watch?v=gjmVMsEuxbo
(the guy is making up an adaptor cable)
Fran
Fran
Tibi - a quick question regarding the contrast modification: There is no pot installed at P1. Do I need to install a pot at this location in addition to removing L7 etc? If I do need a pot what value (2k?)
Cheers
Fran
Cheers
Fran
Cheers
Fran
The 2K pot will only change backlight intensity.
For contrast you need to follow modifications posted on
http://www.diyaudio.com/forums/digi...ansport-shigaclone-story-642.html#post3223611
and
http://www.diyaudio.com/forums/digi...ansport-shigaclone-story-643.html#post3228966
or look in documentation https://docs.google.com/document/d/1vlabZc_1If3x12ox2A5ECZxC0HLGnuOWdM-j9X4b7Q0/edit
page 9.
Regards,
Tibi
i am looking to buy a Shigaclone transport,preferably fully assembled or in kit form with outer box casing also,can the readers recommend fromwhere shigaclone is possible to source,though Vicol is selling this kit,but i will need to source outer casing from other supplier.
Tibi: sorry, another question! The contrast mod calls for a 1.2k resistor. Would a 1k do instead? The reason I ask is that 1k smd are easy enough to find and pull from scavenged pcbs, but 1.2k would be a mouser order....
Fran
Fran
So I went to do this mod this evening. Big fingers do not help!
Anyway, I cut the 2 traces OK and used 2 soldering irons to remove L7, fitted the link between the 2 capacitors. I fitted a 1.5k resistor in place of L7, but unfortunately I broke L7 when positioning it on the new pads. I simply bridged the 2 pads - I hope this is Ok - it seems to be.
I got a little improvement in contrast, and I fitted a pot for P1. Using the 2 together the situation is better. Its not as good as the original shiga, but good nonetheless.
Thanks again Tibi. Is the value of L7 critical?
Fran
Fran
- Digital Source
- Finally, an affordable CD Transport: the Shigaclone story
