A parcel is in today from Romana !(really fast) a lot of work for this winter. Thanks Tibi
You are welcome !
BOM was updated with few missing items and also few minor changes have been put in place.
R15 was changed from 5K6 to 10K
R23 was changed from 15K to 22K
https://docs.google.com/spreadsheet/ccc?key=0AuQF0EAtUutedEhBYW9hSklhOEVmSERodi1xSldyUUE#gid=0
Regards,
Tibi
PS. First ready mounted and tested kits will be shipped this week. 🙂
DIY Shiga KIT
Hi Tibi,
I have received my DIY Shiga KIT
Thanks for all 😀
Best Regards
Francesco.
Hi Tibi,
Thanks for all 😀
Best Regards
Francesco.
Guys sometime ago, I came across a pdf with the top opening cutout for the spindle and the path of the eye in real size. So that we could cut it on plexi or something.
But I cannot seem to find it. Can anyone help ?
dimkasta,
I can't find it, but I have a copy I'll post since it does not have a copyright mark on it.
hopefully there is no issues with this.
I will point out that there is an error in the drawing.
Only one centerline dimension is given referenced to the top two holes. It appears to be the Cl for both the circular cutout for spindle as well as the Cl for the track rectangular cutout. However, the circular cutout is 1.125"dia and the rectangular cutout is 1.00" so the Cl can not be the same for both or the rectangle would be centered. Which it is not. It is offset towards the bottom of the drawing. Knowing that the rectangle is 1" it is offset by 0.125" from the Cl shown.
Steven
Steven
Package is here even though tracking says it is still in transit. No days off till next week though. ) : Quality looks amazing Tibi. Thanks for all of your great effort in this exciting project. Having run a JVC shiga for almost 8 months now I am sure you will get many thanks for making this great project available again at reasonable cost.
Post Office Happiness
Tibi,
Package arrived. Everything looks great. Thanks a lot.
Am I correct in saying that you can leave the two end boards connected as long as the LCD to button relationship is OK with you?
All,
I admit, it will be a little time before I build my kit. Too many projects. It would be great if Tibi or someone else would take pictures during the build and suggest component soldering order, etc. All of this posted in a build tutorial would be very helpful.
Jac
Tibi,
All,
Jac
Hello Jac,
You are welcome !
Yes, you can leave two end boards connected.
we are working on documentation and also a step by step build tutorialwill be presented.
Regards,
Tibi
You are welcome !
Regards,
Tibi
For anyone feeling overwhelmed by soldering the SMD components, check this video out.
He has many good pieces of advice to make it a walk in the park even if you have never done it before. The secret is flux...
EEVblog #186 - Soldering Tutorial Part 3 - Surface Mount - YouTube
Hi everyone, I managed to find some time to put together the shigaclone.
But I cant get it to work snif ...
power supply is fine 8v dc.
All the V1 thru V4 are 5v.
All IC are oriented according to the silk screen and solder joints have been inspected several times with 10X jewelers loupe.
I know I screwed up 3 things.
1. powered up with mechanism laser short in place.
2. powered up with inverted motor spindle/sled/limit switch connector.
3. powered up with inverted lcd connector (18pin thing).
What does it do?
when powered up the disk spins and searches the disk the lcd display shows "--"
once complete the lcd display shows "00" but will accept no more inputs only the TOC button works repeating the read cycle.
I will post some pictures soon.
What does it do?
First up - I can't see your pics...
I've seen this problem a couple of times with some of the shigas I've built. It has always been a problem with the crystal (or reclock circuit). In one case I replaced the citizen crystal with another one, another I had to clean up the pad a little better to solder it on, and in the 3rd case my own clumsiness killed one of the 74ACT14/74AS74 chips in the reclock circuit.
Based on that and my poor understanding of how it all works I can only suggest looking at the crystal, its power supply, connections etc etc.
Maybe tibi can supply more/better suggestions...
Fingers crossed for you.
Fran
Fran
Uploaded with ImageShack.us Thanks woodturner-fran, will try the crystal since I have one laying about, I'm inclined to believe at present that I fryed the LC78601 by inverting its cable. An externally hosted image should be here but it was not working when we last tested it.
Uploaded with ImageShack.us An externally hosted image should be here but it was not working when we last tested it.
Uploaded with ImageShack.usblueworm,
If you are not using Citizen cristal, load your cristal up to datasheet specifications.
In our full kit we provide Citizen CSA-309, therefore C57 and C58 are 8 pF.
The transport will not take any further commands until the TOC is read.
Regards,
Tibi
Regards,
Tibi
Tibi,
My crystal is the Mouser BOM one not the recomender CSA-309.
Ok will play around with the crystal and loading will report back ASAP.
Thank you. 🙂
Thank you. 🙂
I seem to remember Peter Daniels acheived the loading using some twisted pair wire ... if its only a few pF that might do for testing purposes.
If is Mouser part than C57 and C58 are 18pF.
See also crystal datasheet.
Mouser Part #: 695-HC49US-169-U
Manufacturer Part #: HC49US-16.9344MABJ-UB
Manufacturer: Citizen
Description: Crystals 16.9344MHz 18pF
Over each cap add one more 10pF or at least one more 8pF.
Also have a look with a camera or phone on the laser (not direct eye) to see if is working.
Regards,
Tibi
Regards,
Tibi
Tibi,
I recall one of your test videos the laser can be seen quite clearly.
Here is a video I shot yesterday: shiga laser test - YouTube
and another: shiga laser test 2 - YouTube
Tibi,
Looks like your laser is not working.
Check also Q1 and measure collector current while operation.
Regards,
Tibi
Just got done testing Q1 collector 42.1 mA with disk spinning and 2.5mA at idle.
Measured voltages also: whilst spinning. E. 4.58v C. 1.83v B. 3.84v
Uploaded with ImageShack.us Just stacked the 10pFcaps on C57 C58 at least that should be ok now.
Uploaded with ImageShack.us Laser still does not seem to work.
- Digital Source
- Finally, an affordable CD Transport: the Shigaclone story
