F6 Illustrated Build Guide
Did you turn down the bias pots, then re-bias after removing the bulb tester? You must do this and let it settle (get up to temprature)
Thank you for suggestion. I
Thank you for suggestion. I will do it next time.
0.5 V is not 0.5 A
0.5V is around 1A
Bias to 0.5A, that is about 0.25V across the source resistors.
I see.I start from 0.25V.
The smoke come from R1 right channel.
I changed R1 this morning,then measured voltage at R2.
It was 0V.
Changed all caps. Vgs are 3.3V both.
If smoke was coming from the resistors and the mosfets no longer turn on even with 4.5V Vgs then most likely your mosfets, may now need replacing
Maybe explain your current situation better.
The question I have in my mind is why are the mosfets cooking with only around 4V at the gates.
I will change mosfets this evening,thank you.
When I plug from bulb tester, bulb lights one second
Then all LED light up.
After 10seconds,LED turn off then bulb turn light again.
I'm checking every resistors but can't find any failure.
What can happen.
Eg
You have set your trimpots wrong, Vgs is too high
At start up
1) PSU Caps Charge - Bulb On
2) LEDs On - Bulb Off
3) C1, C2 Charge - Bulb Off
4) Mosfets turn On Really hard, - Bulb On
5) Supply rails drop in value due to voltage drop at bulb
6) Leds go out
7) Mosfets go off
