F6 Illustrated Build Guide
Because the transconductance values could be quite different, and you will end up with something entirely different than intended. Infineon looks quite different, so please don't use those, for this mod.
Success of the end result, relies on known measured values of the parts stated, if you use other parts you won't get the result. A lot of measurements were performed to find this combination.
If I were to get in more mosfets and measure them, I could possibly find other suitable combinations, but this combination is very good.
3k might be a little sissy. As Zen Mod said.
2.5k would be less sissy.
Anything in between would also be ok.
Obviously 3k is perfectly fine, however the performance continues to improve with further current.
I don't think I would exceed 10mA though just to ensure a long healthy life for the led.
I was joking
I'm perfectly happy having steady 3mA through LED chains
5mA max
By chance a FQPF20N06 (10S transconductance per datasheet) would do the trick?
I have plenty of them in stock
IRFP150 is not adequate, to be used with IRFP250, I have measured those already.
However IRFP150 Q2 and IRFP240 Q1 would work. Use 23 Ohms for R4. It won't have as good a damping factor as IXTH64N10L2/IRFP250 combination though. It will also be higher in distortion more like SIT3 sounding. Which may be preferable to some people.
Let me check some cheaper options. I will look at some potential candidates. I will check 044 to see if it is a possible candidate to test.
If you can be patient I can order some other cheaper parts in to see what other cheaper options will be equivalent. It could be 2 weeks though.
Thanks a lot 2 Pico!!
yes take your time experiment all you need. I can wait several month
and i am sure that a cheaper version with IRF or FQP will be interesting for many people on this forum.
especially that the F6 transformer can be found cheaper with little perf degradation triad TY-250P 6€ at mouser
