F6 Amplifier
Everyone thinks I'm a nut case around here except Jacco (he's a bigger nut case).
Hahahahaha
Heh. Well, preference of (or similarity to) spreads notwithstanding, I, for one, am interested in seeing as many variations of the circuits posted in these forums as possible. All of this is quite interesting.
I suppose I also have some ideas I have been sitting on, though. They need to be tested in the real world before released for comment, so I understand why you might not post immediately.
Yes exactly.
The idea is technically sound, and works exactly as expected in simulation, but I would like to try it first, before I do anymore preaching (that seems to get me into trouble here, hahahaha).
Does anyone happen to have the common pin out used by Jensen and Cinemag for the PC mount versions of the JT-123-FLPCH and CMOQ-4HPC? I don't see that information in the data sheets.
Also, are there equivalent Lundahl or Sowter part numbers? Maybe the LL1582?
Check Tea Bags' blog here diyAudio - Tea-Bag
He built a board that could use different transformers with a daughter card.
I see pin 1, but I am not sure how that relates to the schematic.
The pin IDs for the Jensen are on p.1, in the diagram. With the dot as the first number, the windings are: 1/3, 2/4, 5/7, and 6/8.
All the windings are identical, but you can take 1/3 and 2/4 as the primaries, and 5/7 and 6/8 as the secondaries.
The Cinemag pinout for the PCB version is missing from the data sheet, but it should be the same as one of their other units,
on p.5 of this data sheet: http://cinemag.biz/output/PDF/CMOQ-2.pdf
Six F6 amp will be build soon😛
These are fine transformers, but a bit pricey.
I would personally consider the line input LL1540 which is cheaper. Difference is the DC resistance is in the 600-800 ohm range per winding, which I don't believe is a problem which also means you could omit the gate stoppers.
You might get a slight LF roll-off, maybe you can simulate to check it's not too much.
I've not checked if the pinouts are the same.
:magnify:
