F5T Bias Problem Cascode Transistor
I contacted Spencer from fetaudio and he said, cascode transistors need to be 180 degree reversed. I will reverse them and I will retry biasing this evening. I hope I will get first sound this time.
Hi 6L6,I suspect the Cascode transistors are in backwards. Check the datasheets and the pinouts.
Hi 6L6,
those transistors has the same pinout as 2SA1930/2SC5171. so they need to be mounted with the backside out. the first prototype F5 turbo Boards had the pinout reversed for the cascode transistors. that may be the confusion.
F5T bias problem solved
hi friends,
problem solved, I changed the orientation of the cascode transistors and now I can perfectly fine tune the bias and offset,
but
I did not go further above 120 mv, because heatsinks became very hot, measured 42-45 degree celcius. I need to upgrade heatsinks, byt he way I did not know the MUR3020W not generate any heat. Should I remove them from heatsinks? because I need more space in my chassis.
I also did a sound test with a cheap 3" 10W 8Ohm full range speaker, sound is very fine, musically involving, make me listen tracks from beginning to the end with that cheap speaker. 🙂
hi friends,
but
the MUR3020's MUST be thermally connected to eachother. if nok you will have currenthog on one output transistor when the MUR's start conducting.
if you need the Space, you could remove the MUR's all together.
thank you so much audiosan for suggestion,
I am planing to remove all MUR's heatsinks to create space,
or another solution is placing fans directly on the MOSFET heatsinks, but I am afraid they will make some noise. Also their vibration may effect transistors so the sound? I dont know..
[emoji4][emoji4] OK I will place the fans on the heatsinks. I have pots for fans so I will fine tune the air flow.
Hi
I placed fans and put the everything back. Turn on the electricity butt
Bias was 2.5mv. I measure the tp 1 2 and 3 4. Just for cruosity. There was no any signal between tp 1 and 2. And cut the electric off. Then turn on again. Now tp 1 and tp 2 was back. ????
I read 730 ohm between. Everything normal again. What hell is happening???
By the way I ran out off trimmer turns I Can not increase bias anymore above 170mv. ☹️
Hi everybody
i solved the problem. i changed cascode transistors with new ones. Sa1145y and c2705y. Now i can properly set the bias. 🙂))
But i blow out b channel mosfets. 🙁((
i could not set the similar mv output from p and n channel. There was 100mv difference. Also the trimmers are very responsive. By the way before everything I changed the r5 and 6 to 2.2k.
try without , just with pot inbetween source and amp
if it's loud enough , just add decent buffer after the pot
if it is not loud enough , you need preamp with few times amplification factor
I think my 2x(0-18) 600VA transformer seems anemic for v2, any chance I can try using 2×(0-40) 600VA with Cascode for v2, I know we could easily use it for v3.
possible , why not
though , it's always clever to keep voltage and current capability on same level ....... so just take care of having enough output parts
Zen are you suggesting I increase the output MOSFET's, but then won't it become something like v3? Plan is to run it as v2 with standard P&N board pair per channel, possibly try biasing the amp a bit low
I'm just saying that , depending of nature of intended load for them (speakers) , you must be aware of OS current capability ..... if load is tough - you need enough output pairs
if load is benign , do what you want ...... you're not in trouble
from personal experience - one of the worst things you can do is - to alter some construction , just to use something you already have .......
Agree Zen, I will be using 4ohm speakers, which ideally should be good for v2's...again, I don't want to alter the construction stuff, just for the transformers sake.
JFET Cascode options
Cascade query.
I am finally locking on slighly undervoltage transformers for F5T V2 version. 0-22V 300VA transformers for monoblocks, which technically means a total of 600VA for the entire project.
From 0-22V AC (this is rated, but the voltage is around 23..something Volts), I get about 30.8V DC, since this is a bit on the higher side for the JFET's, planning to cascode the JFET's & the formula I attempt to figure out Voltage available to JFET's post cascode is
CASCODE FORMULA: rail voltage / (R26+R28) * R28 = cascode voltage
so for 30.8V Rail voltage the following R26, R28 values and Cascode voltage combinations are arrived
R26, R28
1) 10K, 4.7K = 9.92V
2) 4.7K, 4.7K = 15.4V
3) 4.7K, 2.2K = 13.8 V
4)2.2K, 4.7K = 21.04V
5) 1K, 4.7K = 25.39V (which again probably reaches the threshold for the JFET's)
My personal choice would be combo 4- R25,26=2.2K & R27,28=4.7K, but wanted to check with forum if this is an optimum choice or should I move to either option 2 or 5 for better performance, or any other suggestion
Cascade query.
R26, R28
- F5Turbo Illustrated Build Guide
