F5m kit
My amp has been running for 5 full months now with daily use of 5 or 6 hours. It is truly impressive that the bias does not drift at all for both channels. And not a single unintended pop or other noise coming out ever. The only glitches were the 1.6A fuse (on 220V line) blew twice at switch on during this period. Now replaced with a 2A fuse. With such great sound coming from such simple circuit, the designer is really a master.
The power supply boards are Nelson's Bipolar Power Supply. One board and one transformer per channel. The CL-60 & AC Cap PCBs are installed. One per channel. Now looking back, I should have replaced the 4700uF caps that came with the kit with 10000uF. Maybe after I finish the F5T I am working on.
It....is...alive...lol she seems to have awakened happy...and not angry...sounds really good even through my test speakers...still some final tweaking/adjusting to do...
Cheers
Jody
Hi
The heatsinks I'm not sure of right this second...but it's the 2025 deluxe 2U/400mm...forgot a pic with switch engaged and light on...daylight of course but the lighted switch is pretty subtle...and for what little I've let it run so far it's DEAD silent...no hum ,no hiss, no buzz, no noticeable on or off thump
Thanks for the help , pointers, and the kind comments everyone.
Cheers
Jody
Reactions: birdbox
What Nelson did here for the DIY community is unbelievable. So simple a design with one resistor in the signal path, but... the measurements are crazy good. That very slight reduction in gain above 10kHz or so is just perfect, the distortion vs. frequency dependency is almost flat (!! unbelievable !!), and an increase in distortion vs power output even against 4 ohm loads is stunning - minimal, linear. This amp will keep its special character up to its full power regardless of the load connected to it OR the frequency. Then, he gives the compact design for both PCBs as well, preventing wiring/grounding errors.
