F5 Turbo Builders Thread
Toxic Vinyl...Hmm. Havent heard that one before. How do you even exist with the 1000s of chemicals you are surrounded by everyday.
Another note. If you use switchers you cant just load them down with a capacitive load. They tend not to start up. Right now I'm not using anything between the SPS and the boards. Maybe before final build.
You gotta detox. Once or a few times per year do a few weeks of cleansing, go to sauna often, diet, fasting, many things you can do to reduce the industrial pollutants in the body.
Vynil like many other polymers breaks down to shorter chains over time and you may know this, the individual molecules of vinyl chloride are actually volatile enough to evaporate into the air. But it's just a substance that's hard to dispose of. So I don't think you really want to support that industry necessarily. On the other hand we all drive huge chunks of plastics called cars, so I don't know, but definitely worth removing it from the body as much as possible or at least limiting exposure.
I think good ones like Meanwell have startup current limiters or something like that. And ultimately, I will be using 0.2R or even thermistors before the big caps.
Oh ok. Haven't heard of thermistors before caps. I could see that working. Is that something that others are doing. Yeah your right about VC. I used to work for 20 years at a factory that processed PVC day and night. Even stuff that would melt and put out fumes. Probably lucky to be here.
Well, among my LPs, I have a significant number of records that are between 50 and 70 years old. They haven't turned brittle or otherwise changed yet. Can't be that much evaporation from records ...
Also, most of my records I have bought used ... that is not as bad for the environment as manufacturing new ones ...
Regards, Claas
Reactions: Halauhula and Marra
I have a hard time measuring the thermistors, the resistance varies with ambient temperature. The schematic calls for 4.7K ohm NTC, I used the ones made by vishay.
Use the diode function on your meter to test the MOSFET's, google how to test MOSFET's using a DVOM for results.
Hello
I exchanged the jfets for new ones and now the f5 is running again.
Thank you for your help.
I have a question about the Poti 3 and its effects.
What experiences have you had with it or Which settings make sense?
Greetings
Torsten
Reactions: Hotep
Hello Torsten,
Which JFETs and from which supplier did you get? Did you notice any differences between them and the original soundwise?
On a separate note:
Could anyone check out this SMPS and confirm that it's good to use for F5m? I can get a few for very cheap, so I'd be using two in series for ± 24V rails. Should I pay specific attention to the switching frequency or can that be filtered regardless of what it is?
https://eu.mouser.com/datasheet/2/260/MWEC_S_A0007326977_1-2552144.pdf
Hello Billhoerst / Torsten,
starting point with Pot3 is midposition. You can count the turns from fully left /counterclockwise to fully right / clockwise and
adjust it to the mid. More accurate is to measure the resistance of Pot 3. Can be done before soldering it into the frontend of the F5T.
The balance between the N-channel JFet and the P-channel JFet is a question of taste.Don't adjust Pot 3 to the extremes.
Don't do this during operation - music listening!!!
No speaker should be at the output. And a sine wave generator at the input of your F5T. Be careful that your DC-offset at
loudspeaker -output is not running away (keep below 50mV - lower is better).
Don't expect a completely different sounding amp from this procedure. And you should have an oscilloscope to do it right.
Another possibility is to use REW and an A/D-converter (many use the focusrite Scarlet), feed an 1 kHz sinewave to the input of the amp and measure the H2 / H3-profile. You will also need power-resistors at the speakeroutput of your amp to measure this. Many search for a slightly higher 2nd harmonic distortion than 3rd harmonic distortion.
Only some thoughts
Dirk
Reactions: elwood625
