F5 Turbo Builders Thread
OK, I am a builder and can follow a schematic, no problem. I don't really understand the details of what is happening in the amp itself so.....I see there are 3 versions of the F5 turbo. which one should I build?
The versions are, for the most part, differentiated by power level. Lowest power at V1 and going up. The F5T PCB in the store can be used to produce all F5T versions.
@djn
I did not read all your posts, but depending on the tube preamp and the speakers you have in the end you might be more interested (maybe) in something like the F4 or the Mofo...
Sorry I did not take the time to hyperlink to the threads, but they are on the first 2 or 3 pages of the pass forum anyway..
FWIIW,
Max
Great to see so many interested in building F5T.
My build took a long time researching the details. Gate resistor values. Input FET voltage dividers. Power supply transformer size. Power supply capacitor values and quantity. Power supply snubber values.
My costs were approximately $500 for DIY chassis and rear panel kit. $250 for power supply components and $250 for amplifier boards and components. About $1000 total.
Really happy with results. Replaced my class A Krell KSA 200S driving WattPuppy 5.1.
Plenty of volume without seeing any clipping when monitoring the output on a scope.
When setting bias use a scope instead of a volt meter on the output to see the direction of the output offset voltage. I did not use power supply PCB.
I think these will work but I'd like to get your take on it as I'm new to SS amp builds.
