F5 Turbo Builders Thread
Sorry my bad, it has been corrected.
How is that different than the above built TX? With both "ends" covered with the chassis?
Just trying to learn, not argue.
AudioSan,
How many uF are you planning on using?
Ron
BigE There was just one piece 45" long I cut it on my table saw I had to cut it from both sides with multiple passes. There was a lot of holes that I filled with jb weld
it worked out fairly well. Painted the peices with stove paint and strap them together
with a 3/8" gap so fins don't touch in the center
I don't get the ground loop?
Ground loop was from an incorrect transformer mounting design I had posted, I removed the reference, it is correct now.
AudioSan, or whomever,
Is that because the mounting bolt that goes through the center is connected EM through the bolt? Like making a screwdriver magnetic? What if the bolt were Nylon?
Ron
NRG, the 1000VA unit, just take the same + wires and solder or whatnot together, and same with -, and you got a 1000VA tranny with 500VA each side. Double current ya!
Tea-Bag, I'm still learning, so please explain what is a better configuration:
I'm building a dual-mono setup (1 toroid with 4*25V feeding 2 PSU boards)
Each mono will have a dual rectifier bridge, so I will have a total of 4 rectifiers to feed. My toroid will have 4 pairs. So it is better to:
1) have one pair to one rectifier bridge, or
2) double pairs to a rectifier bridge (which would have 2 pairs feeding 2 rectifier bridges).
Thanks!
Hi Guys,
I got my V2 proto's from the store ,going today,Playing very well happy with the results,Everything fell right into specs,bias adjustments are precise,adjust right to it,I don't have a distorion analizer but I got the bias real close and used P3 and my meter across the speaker to adjust P3 got it to.0001 mili's,dc offset,I'm happy!
Been running about 2 hrs ac/dc steevie Ray,Fets are running about 110 F at 300 mils on the bias,
I might build some more of these,lol.
I had a little problems in the begining but I caused them CRS kicking in ,lol.But all the markings ,silk are good ,I like the big traces too,let's you desolder a few times without the trace leaving the board,It's dead quiet ,and sounds good ,good bass!
I did get some help from Variac and AudioSan,thier posts were very helpful and also all the fine people on this site!THANKS
I used some new caps from Apex too.worked out well I used 8x33,000 and 2 I had 10,000 that's per channel,lol.284,000 if I did that right!
Have a good Day!
NS
Hi Guys,...Fets are running about 110 F at 300 mils on the bias,...Have a good Day!
NS
No Smoking, No Smoking? 110F, I guess not but, you have room for higher bias and better sound 😀 From my experimentation, you should be able to get to 130F-150F on the FETs before any worries (probably 55C on the heat sink is 150F on the FET). I see about 10 degrees from FET to sink, YMMV.
"mils"? .001 inch? Right, mV 😉
Let's see, my dual mono F4/BA3 output stage has 33k/33k .1ohm 33k/33k for all 4 rails. That's 132,000uF/rail. 528,000uF for the 2ch 😀
I don't mind it dimming the lights when I turn it on, but I hate it when the music dims the lights!
Supprising you would even bother with our antiquated "inch" Andrew. I don't really know. We very often use thou and I accept that but we also use mil and I have no idea why. It's wrong?
But, then we would be jumping to microns and micro inches??? I think I'll give up on this explaination before i'm 10X to deep 😀
Is there a point of useless returns? 1/2 Farad? 1 F?
Andrew
My father was an aerospace machinist his entire professional life. He often spoke of "Mils" and was referring to "thousandths of an inch", I wish he were still here to ask why?
Country should have gone metric when I was a teenager..........dumb Yanks.
I just called antek to see if my trany shipped. Nice lady said it's still in stock as they are tranning new employes so things are moving slow.. I ordered it on 28th of dec. She said they would ship it out today. Glad I called.
