Marra,
Thanks for posting the message # which answered your question. Very kind of you. This is how a community helps itself. Bravo.
Ron
Ron
I changed out R5/6 today and things now bias up ok.
Now to make a power supply box so's I can try it out properly and have a listen.
I sent out various boards to members to test but I don't think anyone has finished them, right? Comeon, I need a positive report and they're off to the store!
With my limited resources (Asus Xonar DG card--usable as per ARTA 😀) and even more limited understanding, this is what i got (see attached -- had to do some crazy formatting to get within the limit).
No i havent listened to it & i dont have golden ears 😀(but) i do have 1 channel without P3 (i'll need to measure that) and see whether i can hear any difference in between the two
variac. there is at least one that finnished the boards succecfully. without cascoding.
i never got the boards. but i finnished the older prototype boards succecfully. with cascoding. i think it's safe to say the boards are good to go.
there will be, as soon as i get my alu🙂 without costing me $1000 (no heatsinks inkl.). and when my new stereo rack is finnished🙂 it is some space problems in the old one😀
Very good Kroyin. You are going to have fun.
The CURSE!
indeed🙂 damn. I WANT A CNC😀😀 and a garage to put it in🙂
alu without costing me $1000 (no heatsinks incl.)
Is Aluminum that expensive in Norway ?
(as reference : for that amount, I get ~250lb, cut to size, with protective foil if so desired)
no. but the cutting work is. i have to get a better price on the cutting.
this is about 60lbs.
Get a tablesaw. Piece of cake.
nope. it is mm presision. and CNC of logo and such. only CNC and laser cutter can do this job.
and there is some bending too.
- F5 Turbo Builders Thread
