F5 power amplifier
Hello,
Shift PS-pcb 1cm to front, bias new, add cap RCA input GND, and now it ist running very well.
Seems it is now more transparent and faster as my old F5 with unselected parts prototyp with laterals....
I noticed also that the mids and highs have more texture....
my favorit song now is...
Gregory Porter - Eeverything you touch is gold
==> you = Nelson Pass 😀
thanks to all supporters.
Hi
about oscillation:
is my statement correct if i write that the F5 is critical without a "safety" cap at the RCA inputs? I see that the F5 is a pure DC amplifier without caps. in the document its "just" written that it might be an oscillation issue.
Why is no cap like Harry did it in the schematic?
chris
Don't forget that the F5 is a wideband amplifier that goes up >500 KHz.
This from the F5 manual at First Watt:
A caveat is in order here – this is a very wide band amplifier with a high input
impedance. In order to prevent the output voltage from bleeding back to the
input at very high frequencies (thus making a fine power oscillator), keep the
input and output cables separate, and don’t externally connect the speaker
ground to the input ground. Good ground shielding on the input cables is
important, and caution is called for in using Litz and other specially low
inductance / high capacitance cables. I have not seen a specific example of a
problem, but historically it is to be expected when an amplifier’s bandwidth
exceeds 200 KHz. If the amp makes funny noises, runs extra hot, or blows
fuses, this might be an indicator of such an issue.
Harry, your sig in & spk out leads are very close to each other.
Andy
Hi
about oscillation:
chris
I'd say that "safety" cap you refer to at the input is not a DC blocking cap.
It connects from the hot/signal input directly to ground. What it does is
shunt RFI to ground keeping it out of the amp. The amp is still a DC amp.
ICHI
Hey,
for me it was a useful habit to warm up the first prototype, with laterals and no selected parts, with open input RCA´s.
The new F5 as a difference: has selelcted part, an input AC filter 6A (Schaffner) and for internal cabling of the RCA input RG159/50ohm coax wire.
Transformer and Powersupply are equal...
so I guess ,as the new ONE is sounding better, it is more sensitive, cause the IRFP-MosFET are different in high frequency feedback and sounding characteristics??
I do not criticize the F5 circuit and the devolpment....😉:hbeat:
I can live with the feature, that on this F5 there has to be no open input if it is ON
regards Harry
Hello everyone,
for about 2 months the F5 clone has been driving my Audiovectors, the sound is really good, clean without a hum.
I want to improve the parameters of my amplifier. Currently, I have a quiescent current of about 1.75A and a THD distortion of 0.017%, dynamics 90.3dB, noise 97.2dB.
I would like to improve the THD and noise level in my F5. I know this amp can have a THD of 0.002-0.005% and some examples 0.001.
I plan to increase the quiescent current to 2A, but I have to improve the cooling (1.75A and heat sink temperature 57 degrees C), maybe some fans.
Here's a question for you, what do I have to do to get THD below 0.005%.
A photo of my F5
Monoblocks would be a real improvement. Otherwise match all the parts, and use low inductance source resistors.
Also use five series 10R feedback resistors (the exact same part as the 10R to ground), to cancel distortion
due to thermal modulation. That means a new board layout.
I looked at the diagram and it is a question of replacing two 100R resistors connected in parallel with five 10R connected in series. Will 5W resistors be appropriate or would I have to use 10W?
Why does such a series connection of resistors have a better effect on THD?
I have one more question, maybe a lot of these questions at once, but with one tampering with the amplifier I would like to correct the weak points of my F5.
How can I improve the dynamic range of my amplifier?
Calculate the power dissipation in the feedback resistor at full power (roughly 5W), and derate each of the series 10R accordingly. For example, each of the series 10R would dissipate roughly 1W, so derate by a factor of three to ten, depending on the parts and board space available. Use the same part for the 10R to ground. But use the very best
quality resistors for the feedback network, since it determines the performance of even an otherwise perfect amplifier.
This works because all six of the feedback resistors have the same signal on them, and present the same error
(mostly thermal modulation distortion), but this is cancelled out when scaling the output voltage down to
that across only one of the six resistors. All behave the same (if in the same thermal environment), so to a
first order approximation, the error drops out of the equation.
Dynamic range would have to extended either downward by lowering noise, or upward (in current)
by adding additional parallel output devices. Some remove the current limiting circuit, but with added risk.
Also look into adding snubbers to the secondary transformer windings.
