F5 power amplifier
update: now I have an output voltage from psu cap board of 23.5v. But when I connected the f5 boards the bulb lights on. So I checked the boards and Q5 and Q6 were placed in inverse position (cbe-ebc). I've repositioned them but still it doesn't work. Any suggestion?
The psu is ok. 23.5v measured. The f5 board is connected via two wire red+ and blu- to v+ and v++; v- and v--. The ground are all in common.
Those look good to me, but I'm a fellow builder not an expert. Have you been able to follow along with the adjustments in the pictorial linked to a few posts back? Pictures of your full configuration are also very helpful for trouble shooting. It appears you have already purchased a chassis for your build. How are you placing the components?
bcmbob;3753553Have you been able to follow along with the adjustments in the pictorial linked to a few posts back? How are you placing the components?[/QUOTE said:
I didn't tried to turn on the boards because when I tried the leds didn't light on and the fuse blown. The enclosure is from hifi2000, I placed the f5 boards laterally on the heatsinks, the trafo in the center, the caps on the front panel.
For convenience and possible remote placement on front panel - LED, Small copper tube and heat shrink.
Are you still blowing fuses, and/or can you get a voltage reading from the LED pads?
