At a DC level it's the kind of circuit that can be used to keep the speed of a small motor constant with changes in load.
Most speakers are designed to be driven from a voltage source however.
Depends on the amp being used. I guess you rather mean what the effect of the feedback is called as seen from the load's perspective, not the feeback itself:bobodioulasso said:and
and
So, how do you call the kind of feedback described by the second drawing?
a) is constant voltage (drive impedance = 0)
b) is constant current (infinite drive impedance)
@Andrew: yes, one also can make negative output impedance. The whole span of possible output impedance is possible, from -infinity through zero to +infinity. One of course has to take care of system stability, with negative output impedances espcially.
EDIT: Take a look at this article from Rod Elliott:
http://sound.westhost.com/project56.htm
- Klaus
KSTR said:
... except that you chose to personally redefine the commonly accepted term in engineering that "current/voltage feedback" stands for. This only adds to confusion, especially for less experienced readers.
- Klaus
I refer my info to "Malvino, Electronic Principles, 5th Edition, McGraw-Hill International Editions". I have not used any personal definitions at all.
If you can borrow this book from your library, go read the book from page 656 to page 691. It will help.
Standard textbooks can also be wrong, or better said, define things differently.
The european standard, Tietze/Schenk "Halbleiterschaltungstechnik", as well as many online resources define the term in the way I use it.
Issue cannot be solved this way, it seems.
- Klaus
- Klaus
So, don't conclude your own opinion, saying "you chose to personally redefine . . . ", without knowing exactly . . . You seem to have a strong prejudice . . .
Oh c'mon, how could I know that you have a textbook that defines things different to the "mainstream"? So it looked like you were defining things on you own, to me, at the point of when I made that statement. Nothing personal, anyway.
Can we leave it at that?
- Klaus
- Klaus
Re: Balanced F5
I am not shure what you precilely ask but it seems to me that you have to
-either use a balanced F5
-or to convert into an unsymetrical signal. Transfo or opamp.
vitalica said:Pretty please tell me if you can connect the balanced output from AlephP1, 7 second F5 (A + and the other in -)![]()
Re: Re: Balanced F5
- or you can go for Michael Rothacher's Amazing Circlotron, an amp derived from F5 that has a balanced input only.
Nelson said it'a a cute design. 😉
http://www.audiohobby.com/
or
http://www.passdiy.com/default.html
or
Hi all
I built one channel of the F5, and now it's under test.
I have some problems. I am running the bias at 350 mA, becouse I have not jet enough heatsink, but I think it should work well.
The problem is that the offset that is 0 mV at idle, rises at about two Volts at clipping, that is about at 18 V when I give a sin wave of 1 KHz. Rails are +/- 23.5 VDC. That without load.
If I connect the load (8 hom 100W resistor), the clipping arrives at 8/9 V and the offset rises at 10 V or so.
Could please anybody give me some advice on this problem?
Thank you
Some pictures of the device under test 😀
Thank you
Strange behaviour.
Aren't you oscillating with these long wires?
Though it seems you added decoupling caps.
(I would wire the speaker return direct to the psu ground.)
Nice caps and nice tweeter ( i have the MDT32s)!
Thank you for answear.
Caps are just DC filtering, can that be a problem?
Yes Papa, the positive wave start to clip and more the volume goes up more the negative wawe decrease, without clipping, until DC is reached. But that just under load. Without load both clips at 18VDC and offset rises at about 2 VDC.
Where have you seen tweeters Bobo?
On the Imageshack.Where have you seen tweeters Bobo?
Isn't yours?
Is your generator dc free?
In the two photos I posted there are no tweeter. Maybe you are referring at some other photo in other tread?
I don't have a generator. I just use a CD with sample tracks connected to my pre, that is DC free for sure.
Hi Bobo
not jet, i'm at work
This is the actual schematic, nothing special, just added filtering caps and no NTC.
Not the shematic but the drawing we can partly see on your second pic (the wiring).
May be you could unsolder Q1 and Q2 which are not compulsary, just in case.
- F5 power amplifier
