F5 power amplifier
That is one way.
Another is to cascode like Borbely using JFETs, which is much simpler.
In this case, because of the 4mA or so bias, I would recommend using J111 / J174 as cascode devices (instead of 2SK246 / 2SJ103).
You should get a good 5V Vds on the Toshiba's then.
And yes, have done that many times in various circuits, including my AX-J 100W.
Patrick
slr 5000 said:
hi all
is the f5 scalable to higher power levels like the aleph series of amps
say more output devices and voltage with bigger sinks to match
if so would 100w into 4 or 8 ohm be doable
im currently using 2x f5 to biamp some esl and i love the sound at low volume but they do struggle at anything over half level
i know the f5 is not suitable to drive my esl but the sound is so nice id prefer to look at ways of getting more power than to build another amp
cheers
It wont be an F5 anymore, and the sound you like may be gone too
I fear the same even with just double output pairs
I suppose that just the slightest change, and it will sound different
Maybe you need a good 60-100watt, class AB and 1ohm stable
I will probably get shot for saying that :clown:
bobodioulasso said:
Not true, and there are many other advantages to go this way.
I know
And sounds like impressive setup
But you also admit to use 150watt AB on woofer, which was my point, sort of 😉
Though. when I suggested paralel output transitors with slightly raised bias, it was turned down with " no more power and still 25watt"
Kind of same thing
As would be a more powerful power supply, mono amps etc.
Though I understood it was about having more power to drive ESL
And thats what I relate to
I asked for impedance specs, but no reply
I dont know if active crosssover and multiple amps is a possible option with ESL
We may misunderstand each other
I plan to do 2way, and use F5 to drive a compression driver/horn, and AB amp to drive 18" woofer
So we do agree, sort of
I don't know if we mean the same thing. If current feedback means transconductance or very high output impedence, then as the load goes up (at risonance for exemple) the current remains constant, while the voltage follows the impedence.
Or not :scratch:
