would a heatsink like this be enough for both channels
from what I can see, its basically an 18" cut of a variation on this extrusion
-Jared
-Jared
Probably, but as others will tell you , it would be a lot more efficient and likely to be enough if you cut it in half and turned each piece on end so that the fins are vertical. Or even better in four pieces 4.5" tall, and use 2 vertically on each side.. one for each MOSFET
Dougie085 said:Oh ok. So like 20VAC? Because you adjust it down to the correct voltage? What voltage do you need with the ZV5 PSU?
For your info, attached is mine as built for the supply rails of
about +/-20V.
Dougie085 said:The ZV5 will work with the 20VAC and everything won't it?
Is your PSU regulated? Also any particular reason you used 4 22,000uF and then 2 33,000uF?
20VAC works fine with me. You could increase to 22VAC.
Still you could use 35V-rate caps.
From the picture, you can see four MOSFETs/ch. Two are for
the regulators, and another two are gain MOSFETs.
No particular reason. I'm just a poor man...
You could use 33,000/35V for all...
Please forgive the dumb question, but what's the purpose of R1-8 in that power supply design?Variac said:http://www.firstwatt.com/downloads/f4_om.pdf
There is a power supply schematic towards the end; Page 15
Mark
dfdye said:... but what's the purpose of R1-8 in that power supply design?
These resistors and the caps that follow form RC (low pass)
filters for reducing ripple on the two power supply rails.
Dennis
Dougie085 said:So yours just doesn't have a pot adjustment. I believe the ZV5 does right? I don't know either one really isn't all that complicated.
I'm talking with you just about ZV5 PSU...
Dougie085 said:Ok sorry I'm a bit dumb at the moment. It's been a few years since I've had to read schematics and what not.
Opt for the ZV5 supply!!Quiet ,Quiet,Quiet!!!
BABOZEN!!!!
- F5 power amplifier
