F4 Beast Builders
Variation between 5 x IXTN40P50P devices
For all 5 devices it ranges between 6.1 and 7, but 4 out of the 5 devices range between 6.8 to 7.
I'll probably repeat the measurements one more time, but I am mostly interested to see whether they are a reasonable match to 48N60P when measured under identical conditions. KISS
Temperature of heatsink right next to mosfet was 52.7C
Also based on the measurements performed at 22.1C and 52.7C it appears a difference of 0.1V between cold and hot is all that is required in the biasing circuit for 40P50P.
So maybe a 0.2V difference in the biasing circuit between cold and hot across the pair of 48N60P/40P50P will be adequate.
soundhappy was so nice to give the link a few postings above....
http://www.moremusic.nl/pass_labs/Manuals/Manual-XA25.pdf
while 2picodumbs tried to convince me of his teleportation abilities on his saloon table..... :--))
I noticed the user manual doesn't say anything about 2 ohm load, unlike
the prelim info we saw earlier.
But dang, <0.01% distortion for 8 and 4 ohm load over the entire power
range is nothing to sneeze at.
And the dimensions are pretty room friendly; just put it where your FW
amp currently resides. 🙂
Dennis
