F1 Group Buy
Want Boards, can't WIKI
Hello Peter,
I'd like 2 boards and info on the ps boards (I saw you had some but not where). I cannot figure out how to add to the table you built. Is there more info...or is it a Mac problem?
Anyways....2 boards and PS info please.
Thanks!
Re: Want Boards, can't WIKI
belkinmousepad said:
Hello Peter,
Thanks!
I edited the Wiki for you.
Here is the Direct Link.
http://www.diyaudio.com/wiki/index.php?page=F1
David is the PCB designer, Peter is doing on some other work on F3-F5 PCB's on another list. David will be distributing the F1 boards.
Peter has power supply PCBs available.
The F3 model from him will work.
I too would like a pair of the boards. I tried to add my order to
the list but was not sucessful could you add my name to it.
I just occured to me that I ordered a pair of Pass A40 boards
about 30 years ago a day or 2 before newyears also.
Extending the GB deadline to Jan 9th
F1 GB participants,
The GB is scheduled to close Dec. 31st, 2008. Since we are so close to 100 boards and a price break, I'd like to extend the GB deadline to January 9th. If no one objects, this gives us a chance to get a few more participants and the board cost drops to $11 plus shipping.
-David
How long do they need to run these boards and do they need
payment before they start this order? The group buy stands at
82. When the total reaches 85 it will be cheaper to order 100
than 85 boards. I sure hope you can take paypal!
Hi Woody,
I'm going to start taking payment shortly via PayPal. I bet we'll get a bunch more board orders next week after everyone's back from Winter vacation.
We only need 9 more pairs ordered to get the next level of discount to get the cost down another couple of bucks per board.
I have samples scheduled to arrive today. We will be ready as soon as they are verified.
Happy New Year,
-David
He everyone,
The F1 GB Price is now $11usd plus shipping. We have met the minimum quantities.
Attached is the prototype F1 v1.0 board received from the board house. Some minor tweaks have been made and the production board will be based on version 1.2.
-David
Buckapound said:
One thing to think about for those of you who are having trouble with broken taps is that "forming" taps are a little harder to break that cutting taps. They essentially re-flow the metal rather than cut out chips and are great for softer materials like aluminum. They just look like standard screw threads that have a little cam or lobe shape, without the cutting flutes of a standard tap
As always whit taps, be sure to drill the exact right size hole, which is different for a forming tap than a cutting one. Best to use number drills. And there is a specific lubricant made for tapping aluminum, although most any lubricant is a lot better than none.
In my experience carbide is a terrible material for taps, unless you are tapping abrasive materials like fiberglas. DW8083, are you sure they're carbide and not cobalt? Big difference. Murder to get a broken one out, too. With HSS taps you can just fill the hole with acid and wait for the tap to rust out.
--Buckapound
Typically in the fabrication and machine shops I have owned we used rubbing alcohol for tapping aluminum.......it prevents the tap binding up and thus breaking where as oil based lubricants tend to clog up .....best bet is a water soluable based tapping fluid
just my 2 cents
Happy New Year everyone
just my 2 cents
What would you recommend for 0-80 holes in copper pipe fittings? I have tried 4-40 set screws for some DIY mics but they are just too big to catch the short piece of the capsule that sets in the pipe fitting.
