Explendid amplifier designed by Michael Bittner, our MikeB
I have already tested rmaa and the resault are good. I'm curious why when I connect the signal cable there are schowing noises on the chart (last one screan). When I connect a very short signal cable the noises are on the lower level. Without signal cable spectrum is quite flat at -130dB, just like in rmaa test.
Next one measurments (this time using Audigy1):
Load 8R
out 10V
ver with 2n5551/5401
ver with mpsa92/42
Now bias is 200mA, it is much better with higher bias (two pair output dev). I must work on my meas system, now it looks like chaos. Low freq products may be are result of my PSU, I'm not sure.
Something is very wrong with 2n5xxx version, the high order distortions are too high, like the bias is not correct. Have you measured bias in vas ? (Measure r15/17) Also 3rd harmonic is too high, it should be 10db lower at these power levels. (Might be signal source as both amps show the same) You could try using a CD-player as signal source, simply burn some test signals on cd.
With these distortions for the 2n5xxx the mpsa version must sound better. The mpsa version looks much more like it should be.
Mike
Hi Chris, let's hope your computer allows you sound...
Why a soundblaster ? For measuring there are better soundcards, like the Esi@Juli, having balanced inputs and outputs. The rated 0.004% from the soundblaster will be real world above symasyms thd... 😀 Okay, already bought...
Like Holger said, input is max 96khz samplerate, giving max 48khz.
BTW, which OS do you use ?
Mike
Hi ya all, especially Mike,
Didn’t have much time lately, but I’ve done this so far. This is the newest PCB version. Not ideal, but I think it’ll be a little bit better.
First of all, I’ve moved PSU ground (electrolytic capacitor’s ground) away from the input section, by placing a thick jumper beneath the PCB, connecting one + and one – of the 1000µF/50V electrolytic capacitors. Not quite elegant, but this line won’t interfere with the amp’s input anymore. By placing it beneath the PCB, it’ll also be a little bit further away from the 47k/220pF combination as well.
Electrolytic capacitors 1000µF/50V have been turned around for 90º to straight up supply leads feeding output trannies.
I’ve moved 47nF capacitor from the left of 4,7Ω/2W resistor, to its right, moving it away from the input section.
Last, but not least, I’ve turned one of the diff. input trannies, thus providing much better conditions for bonding these two together.
If anyone is interested that’s all for now. I’m in “obtaining components” phase right now, much as thinking of building four of these to convert my speakers into active ones. As time passes by, all the chances are I’ll stay with passive speakers.
Best regards to ya all,
Nick
Hi Mike,
I use XP Home. It was good until now and usoft doesn't know how to fix it.
Hi HBarske,
A/D is supposed to be 192 KHz. The published specs seem to look good, we shall see. The older card was in trouble at 18 KHZ, so this is an improvement. I saw it on sale for $134 CDN, so I picked it up. Also hoping a mjor change would shock XP into working. No such luck.
I do plan to buy a DSO with FFT functions, so this is good enough for quick things on the bench.
Mike,
Don't worry, I'll measure THD with my normal stuff and look at the residuals. Might actually send the residuals to the sound card. I'm sure that will extend the usefullness.
-Chris
Hi Chris, the specs say:
24-bit Analog-to-Digital conversion of analog inputs: 96kHz sampling rate
And this is rather usual for this type of soundcards. There are few who really do 192 A/D. I remember once having an EMU 1010 which was spec'd to do 192 on the A/D side, but it definitely did not. Noone of the music guys out there obviously was interested in that, so noone seemed to have noticed.
I second Mike's proposal of the ESI Juli@, that's a good one.
Hi HBarske,
Oops, that's not what I was interested in anyway, thanks for pointing that out.
The spec I was actually looking at was:
Frequency Response (-3dB, 24-bit/192kHz input): <10Hz to 88kHz (Stereo only)
When I should be looking at :
16-bit to 24-bit recording sampling rates: 8, 11.025, 16, 22.05, 24, 32, 44.1, 48 and 96kHz
As long as it doesn't brick wall around 22 KHz, I can live with it for quick bench tests. I would love a better card, but I'm on a fixed income and trying to save for a DSO.
If I can get my sound working, I'll let you know how it does.
-Chris
