Explendid amplifier designed by Michael Bittner, our MikeB
borys, as long as voltage does not get above 40v, the mpsa18 should be fine, it has max rating of 45v.
270mv gives an effective hfe of 122. It's possible that the turn on thump is caused by that. The mpsa18 has at least 10times the gain. And it is ~4 times faster...
About your grounded chassis, is it only connected to power-gnd ? You should keep signal-gnd isolated from the chassis.
Mike
Hi dytln_02,
Thanks for responding. My audio issue is with Windows XP only. This is the third sound card in this computer since an update killed it.
Hi borys,
Could you please measure the DC offset on each side of the differential pair bases in mV? A turn on thump suggests either a problem with both 470 uF caps (maybe the type is bad for this), or a mismatch between the gains that takes time to be servo'd out by the diff pair set.
-Chris
anatech
I have bridged DC cap (470uF) and on thumb is all the time -2,5V, the cap i low impedance samwha WL. DC offset on each side of the differential pair bases is aprox 950mA - very high.
I have changed a diff pair couple of times with not matched (658/625, 658/670) mpsa18 and out offset voltage is 182mV all the time (it was 2,5mV).
I have manage with this thumb.
I have hanged diff pairs in both channels, not in one only - this was prapobly the reason of this offset.
With both channels with mpsa42 offset was 2,5mV.
With mpsa42 and mpsa18 in secon channel offset was 180mV all the time.
Thumb is but very very smal.
THANKS VERY MUCH
Now I know almost everything about symasym 🙂
Hi borys, with the dc-blocking cap shorted it is normal to have that big DC-offset.
Okay, i did not understand "hanged diff pairs", what was the problem ?
Has the DC-offset now returned to 2.5mv ? Everything above 5mv is abnormal for symasym.
A slight turn on thump is normal, but should be too small to be audible/visible.
With a 658/670 match in input and the DC-cap, the DC-offset still should be very low (far below 180mv).
Mike
borys said:
If I disconnect input there is the same offset on r2. I supposed that is a grouding problem becouse I had EMI distorsions (even heard), when I connect my CD I can hear distortions from high voltage network (~240V) at a higher level, with another amp everythink is ok. Input is very sensitive.
Most probably signal wiring problem. Also, try to diconnect PSU 0V from chassis (you wrote it was earthed).
Whitout signal cables (PCB) and grounding chassis is still 32mV. Maybe there is something wrong with the vas ? I'm wonder why changeing the diff pairs doesn't change the offset voltage. When I heat up one of mpsa18 by the soldering iron offset normaly change with the hfe of mpsa18.
22k virable resistor decrease distortions from my CD (I have one 22k only).
