Explendid amplifier designed by Michael Bittner, our MikeB
Hi dytln_02, i played a bit with your suggestion in sims, it should work to create a headphone amp with this topology.
I choosed +/-16v as dc-source (from 12v AC rectified)
I have not build it, only sim'd, but should work quite good...
As you can see, i made some more changes.
Bias in outputstage is ~200ma.
Mike
"Standards" ask for an output impedance of 120Ohms. However most headphones (Sennheiser, Grado, Akg) are designed with an output impedance of 0Ohms in mind and sound best when driven that way. Iirc, only Beyerdynamic still designs with 120Ohms in mind.
Mike
thanks mikeB
I Will Try this Headamps ......
I will report the result next week. 😀
Hi dytln, heare are your numbers:
THD at 20khz, 3.3v (~0.01%)
h2: -80db
h3: -90db
h4: -125db
h5: -133db
higher order below noise
Power into 32ohm: ~3watts
Gain: ~1:12 ~20db
Openloopgain: 1:1400, -3db at 48khz
Feedback: 41db
GainBandWidth: 61mhz
Unitygain at 6.5mhz 157° (unitygainstable)
Stable into capacitive loads
Phaseshift at 10khz: openloop 13°, closedloop 1.7°
Frequency response: -1db, 3.3hz to 150khz
Slewrate: ~14v/us (enough at these powerlevels)
I optimized the circuit for stability, not for impressive THD numbers.
Mike
Hi Michael
Congratulations on a well designed amplifier and to all the fundis that assisted you here and there with some of the finer details. I have had the pleasure of building 4 of them for an in car 4 ch amplifier and have enjoyed every minute of listening to music on it:cheers:
The treble clarity is amazing. The bass seems defined but does not dwarf the vocals or upper frequency instruments. Just my 2cents worth.
Attached is a photo of the configuration I have used. I have not built a cover for the case as I was to busy enjoying it in my car to care about the cosmetic side of things.
@mikeB
Can You give Voltage Measure Across Resistor, So I can debug it ?
I have finish build One Channel...
With Input Connected No Hum, Hiss Only AT 3/4 Volume, maybe from soundcard (Chaintech A7V)
I Can Say how it's sound because it's only One Channel
I will build another channel...
edit :
I Can not Say how it's sound because it's only One Channel
Is 1A +16 0 -16v PSU Enough for this Headamps ?
