Explendid amplifier designed by Michael Bittner, our MikeB
Hi Mike
The Symasym_3, does it have anything to do with the higher power version? May be not, may be it's just an improvemtent over the previous one, isn't it?
Pardon me, I'm jumping ahead of myself...I hope I don't fall
but the enthusiasm makes me rumble too. What a pain!
Hi !
Grataku, right now i have no plans with balanced input, you might consider a converter/buffer ?
John, the sym5_3 is about pcb, i changed some power grounding. A high power version will be a redesign, using slightly different topology, giving a symasym6... (folded cascode with triple darlington output) Let's see if it is anything good and still has the quality of symasym5.
Mike
Upupa Epops said:
If you will use cascode, Mike, try fets, maybe you will be surprised.... 😉
For output or cascoding devices ? Mosfets ?
dtrif said:
Mike, which output transistors do you prefer (sonically), 2SC5200/2SA1943 or the transistors of the original design ? I ask because you have tried both.
Dimitris, i am not sure, i did not make a direct comparison. I have the feeling that the Toshibas do sound softer, and the MJLs a bit more agressive/dynamic.
Mike
Re: complex load
Cortez said:
MikeB, could you make a little test for me, please ?
I would like to see the output @ 10kHz squearewave with 8R + 1uF load, on half power.
Thanks!
I can do it, and guess I had probably done it.
You have electrostatic speakers? Otherwise this test is good quite for nothing, as it is highly unrealistic load. Better think about frequencies at sides of bass speaker resonance, the immediate power is highest here.
Hi Mike,
most of the advantages are lost without carrying the balanced line to the input differential. Plus all the extra components in the converter.
I was thinking in would be simple to add the cold input to the feedback side of the differential.
I am all for jfet input. I have a load of them I'll probably never use.
Mark Levinson did this kind of solution. The only problem is the low input impedance of the feedback point. So they used some input buffer (double push-pull emitter followers) to get same input impedance on both + and - input
sajti
Re: complex load
Thanks!
In paralell or series ? I guess paralell... Grataku, i would use Wima MKS2, it's likely that it wouldn't even warmup... I used them in ClassD-Filter, 300khz squarewave kept them cold.
Mike
