Explendid amplifier designed by Michael Bittner, our MikeB
Wonderfull boards PMA, and completed service, we have the parts positioning too!
Great.... i can see that will be very pretty when really constructed..... post images for us when you started.
We will be waiting..... i cannot wait to listen some from you!
regards,
Carlos
Re: Wonderfull boards PMA, and completed service, we have the parts positioning too!
regards,
Carlos
Carlos,
it was Michael who had designed it, I only added 1 resitor and changed dimensions .....
Tribute to Michael !
Well - I am interested in the result. The OLG -3dB point is about 30kHz, as I verified, this should be a good starting point for a good sound .. ;)
MikeB said:
Pavel, maybe you can use the exportfunction from eagle and create
bitmaps with let's say 300dpi, or for very nice printout with 600dpi ?
If Chris then prints it with the correct dpi...
Mike
Michael,
they were made by export function from Eagle, at 150dpi, just for filesize. I can make them in higher resolution, if any request here.
Re: I like this board, the colors are green, yellow and gray blue
destroyer X said:
Very alike brazilian flag...hummmm, i think i will stole this schematic to produce here.
Michael, already, did not decide to produce in Germany!
ahahahaha!
regards,
Carlos
Good point Carlos!
We will support you by design, engineering, quality control and maybe production, and you will add your "Explendid Copacabana Marketing" ! ;) :D
Pavel
