Explendid amplifier designed by Michael Bittner, our MikeB
Hi Black,
Coupling and matching are important. That's why they are laid out close together on the board. That is also why prepackaged matched pairs were available and expensive.
Somewhere "back there" you can find a post of mine with pictures. I nrmally match, grease and enclose pairs in heatshrink tubing. Marantz had some great spring clamps that held the transistors together and was also grounded.
-Chris
Hi
I’m currently reading this thread and the design seems interesting and I think I will built it.
I am at page 25 of the thread and I don’t know is someone asked the same question at the following pages.
I would like to ask about the driver transistors which can be found but are a bit expensive, can they be changed with D44H11 & D45H11 (same pins 80v 10A 70W 50MHZ hfe=60) which is cheaper and is designed for driver applications, I don’t know if the bandwidth of 50Mhz will cause problems.
The second question is about the output transistors MJL3281A/MJL1302A which I can’t find anywhere, can I use another transistor, can i find them in a eshop?
I found the following replacements in datasheets 2SC3281/2SA1302, are these ok to use, any other recommendation?
Thank you
Alex
Alex, the 2SC3281/2SA1302 can't be recommended (As Chris already said) unless they were pulled out of an old amp.
You could use 2SC5200/2SA1943, but only buy from reliable source !
About your suggested drivers, i don't know them, but 80v seems a bit low. (also hfe = 60)
If you find a good source for 2SC5200/2SA1943 (Toshiba), look for some nice toshiba or sanyo drivers. The drivers need hfe of min 100.
Maybe:
2sa1930/2sc5171 Toshiba
2sc2344/2sa1011 Sanyo
2sc3298/2sa1306 Toshiba
Mike
Hi Alex,
Any 2SC3281 / 2SA1302's you find are probably fakes.
They have been out of production a long time now. They were very popular and may have been the first really good fakes. Forget them, the odds are against you finding some real ones unless you pull them from a piece of old equipment yourself.
Mike has an excellent list of driver pairs there. I like the Toshiba products better.
-Chris
Those ones are the drivers i use AAK
Well...they are my standard drivers to all amplifiers i use to make within this power and voltage range.
They sound very good...simple and reliable...cheap plastic ones....no need to insulate nothing.
I love to compare amplifiers...this way, i use the same transistors...so.... if the sound is different, beeing the same transistors, they will be out of suspections.
regards,
Carlos
