Peacock..
@xrk971
I did the 20" and the depth is 4". The bass is quite unbelievable for the size.
@Dave
True. That's what my wife said too. So planning to move it to another wall!!
One small correction though, that is paint, not wallpaper😀.
Later
Peace
Jetlag
@xrk971
@Dave
Later
Peace
Jetlag
Slowly.
So I built the twin to this one:
but tilted them like Switters. They are now my computer speakers together with a sub.
The E60 sounds great but had to be sealed by the long side of the driver as it bulged there, when I swept the speaker slowly from 50 to 400 Hz I heard distinctive air leakage at certain frequencies.
Also a loose segment in one horn´s end was revealed by the sweep.
Next step is to build some HT satellites. Just need to get them more Waffy.
They don´t look so nice right now as they got smudged by the black silicone sealant.
They will end up like Switters´s eventually, I hope.
that's not fair. The one thing that really keeps this thread on the rails is the speed at which these things are pumped out.
It cannot be built until it is designed.
dave
Hi solhaga,
I had the same problem, I used vinyl glue to seal the back panel and this leaved some leakage. I tried to seal them pouring some glue from the horn mouth and then rotating the cabinet to let it flow along the corners formed by the plywood and the foamcore board.
In my experience vinyl glue is too liquid, it's easily absorbed by wood and "shrink" too much when drying. Next build I'll try a more dense glue.
Hi solhaga,
Wouldn't Contact Cement be a good alternative?
I never tried contact cement but if it is fast setting or if there are solvent reacting with polystyrene I wouldn't use it, otherwise it should be ok.
I use silicone sealant
From the photo it seems that horn throats are closed... or it's a trick of my declining sight?
No, they are not closed. The foam I´m using is not rigid enough so I have to put spacers at the top. Like bridges.
Mmm... this could be an useful trick, thank you 😉
solhaga, you, without a doubt, win the ugly award. They might be the best sounding of the bunch but OMG man! 😀
LOL, but once he puts the front baffle in place you will not be able to see the mess inside.
Solhaga,
What are the channels made of? Black foam core or is that like vinyl? There are no points for internal beauty as long s it sounds good😉 if channels are foam core and cut cleanly, they seal nicely with cheap white glue. They are also stiff in compression and would not require bracing at throat.
well holy cow i was walking through the mall and i saw an "OPENING SOON" sign for a Dollar Tree store. soon i too will have foamcore at LAST!
hey can we change the name and call foamcore cornu's to cornFu's (the capital F is in praise of foamcore)
It is 5mm XPS foam that is normally used as floor underlay.Solhaga,
- Full Range
- Ever think of building a Cornu Spiral horn? Now you can!
