Ever think of building a Cornu Spiral horn? Now you can!
Peacock..
@xrk971
I did the 20" and the depth is 4". The bass is quite unbelievable for the size.
@Dave
True. That's what my wife said too. So planning to move it to another wall!!
One small correction though, that is paint, not wallpaper😀.
Later
Peace
Jetlag
So I built the twin to this one:
but tilted them like Switters. They are now my computer speakers together with a sub.
The E60 sounds great but had to be sealed by the long side of the driver as it bulged there, when I swept the speaker slowly from 50 to 400 Hz I heard distinctive air leakage at certain frequencies.
Also a loose segment in one horn´s end was revealed by the sweep.
Next step is to build some HT satellites. Just need to get them more Waffy.
Hi solhaga,
I had the same problem, I used vinyl glue to seal the back panel and this leaved some leakage. I tried to seal them pouring some glue from the horn mouth and then rotating the cabinet to let it flow along the corners formed by the plywood and the foamcore board.
In my experience vinyl glue is too liquid, it's easily absorbed by wood and "shrink" too much when drying. Next build I'll try a more dense glue.
Hi solhaga,
Wouldn't Contact Cement be a good alternative?
Solhaga,
What are the channels made of? Black foam core or is that like vinyl? There are no points for internal beauty as long s it sounds good😉 if channels are foam core and cut cleanly, they seal nicely with cheap white glue. They are also stiff in compression and would not require bracing at throat.
well holy cow i was walking through the mall and i saw an "OPENING SOON" sign for a Dollar Tree store. soon i too will have foamcore at LAST!
hey can we change the name and call foamcore cornu's to cornFu's (the capital F is in praise of foamcore)
Solhaga,
It is 5mm XPS foam that is normally used as floor underlay.
