rossl said:
Russ,
You still may want a uC just to turn off the automute.
Thanks for the headsup Ross!
Had a very similar situation on the prototype opus.
Cheers!
Russ
How hard would it be to have a 5-7 channel version of the DAC board that would support the DSD and all that? I'm guessing it would mostly be just rewiring the outputs and what not. But I'm most likely wrong. Not sure I would need a 7 channel...probably wouldn't be something that people would order a lot either so take this question with a grain of salt
Ross,
Well im very pleased that you have put the part under a microscope and exposed a few things. ALso the fact you are happy with the sound with a couple tweaks of yours is really good. Are you planning to make a DIY kit from your experience or is Russ the one that takes care of most of these? It would be awosme to get this DAC into many hands to see the potential it has. I ask this since doing the PCB's is really not the business my company is in, but its necessary in order to get the part to anyone who wants it.
Dustin
Dustin
Dustin, doing PCBs is my business. I have been designing PCBs professionally for over 20 years.
I started very young
I have designed hundreds of boards, and some of them have reaped $ millions in sales. I didn't get a commission
The Twisted Pear guys have a nice setup because they have assembled boards for sale. The boards I have sold here on this site have been bare board kits with documentation.
Dustin,
I can only speak for myself, but I do plan on doing DIY kits and PCBs. If this things works out as well as I hope, I think there will quite a few of these out there.
I will actually be ordering my first batch of PCBs for this chip in the next day or two. Probably Monday. So expect a lot of questions between now and then.
Brian Donegan is my cohort and friend. He handles the kit side of things, I just design circuits/PCBs.
Cheers!
Russ
Cheers!
Russ
dusfor99 said:Hi Russ,
Tell you what, you send me one of the PCB's once its finished and Ill pop a chip on it and see what the THD and DNR turns out to be.
Dustin
You have a deal, I look forward to it.
Cheers!
Russ
Dougie085 said:Maybe because its a good solid transport at a very reasonable price and with the dac upgrade becomes an AMAZING CDP/SACD player
Exact
Russ, Brian any idea of the price goal for this new DAC? I know the chips are a lot more.
Not yet, but I am gonna look at it today. The board is still changing, so hard to do at this point.
Re: Re: PCB top (preliminary)
Dustin, would you recommend against doing I/V on a seperate board connected via wires then?
Dan
dusfor99 said:
Just to throw this out there for everyone using the part, we have found that the MOST inportant thing in order to get the THD to be in the >-116 region, you really need a nice line of sight solid ground plane back the AGND_L and AGND_R. Basically, the ground plane should have as little inteuprtions to these returns from the load (the I/V converters)
Simply rerouting grounds we have seen 10dB differences in THD performance.
Dan
I understood what Dustin was trying to say as just to make sure your I/V GND has a direct uninterrupted path to the AGND pin.
I actually think noise wise there may be some value in isolating the I/V stage from the rest of the DAC. At least this has proved true in the past.
One other consideration is flexibility. What if you decide to try a new I/V scheme? Or, even treat the DAC as voltage output?
Cheers!
Russ
Cheers!
Russ
rossl said:I have never heard a CD that needed de-emphasis.
I think it can be ignored.
Oh I certainly agree it probably not worth bothering with!
That said, I actually do have several older CDs that do have pre-emphasis. But I rarely play them.
It just seemed like a natural thing to do.
You would be amazed how many emails I get asking about it.
Cheers!
Russ
- Digital Line Level
- ESS Sabre Reference DAC (8-channel)
