ESS Sabre Reference DAC (8-channel)
... I have been able to do the same via XMOS for quite a while now. ... I have also experimented with generating the bit clock and word clock by dividing the master clock. Which worked well, but requires two master clocks.
Oh, you have already achieved a stable play of 384 kHz/32 bit sources with OSF=ON, Jitter Reduction=ON, DPLL BW ="the lowest" on your Buffalo II/80 MHz/100 MHz. It's great!
Is the XMOS-based USB interface capable of seamless play of 44.1 kHz to 384 kHz without changing its wiring or configuration?
Anyway, I've been actually waiting for your X-MOS product for more than one year without buying other similar kits.
I really hope your superior product is realized immediately and many people can reproduce the sound you already have and enjoy it.
By the way, Chiaki's approach is one master clock for one sampling frequency series approach.
Does anyone try any synchronous configuration of I2S for ES9018, with such lower MCLK frequency range as 11. 2896 MHz, or 22.5792 MHz for fs=44.1 kHz source?
I just tried 22.5792 MHz synchronous MCLK input to master clock XI pin of ES9018 and found it feasible enough for from fs=44.1 kHz to fs=352.8 kHz sources under OSF = OFF conditions.
small update on QA-550/Buffalo II syncronous combo
According to the ES9018's datasheet, IF you only play 16bit/44.1khz files, 11.2896mhz is enough for
OSF mode. I had tried it after previous post and the result was much better than bypassing OSF.
Now Mid and Hi are much cleaner and more opened, and more "natural" in addition to detailed/better difined sound
Hi, wktk_smile,
Thank you very much for your replies to my question!
Yes, you are correct. As far as a master clock frequency > 192 fs, OSF mode can be ON.
Have you already tried, 90.3168 MHz(44.1 kHz x 2048) or 98.3040 MHz(48 kHz x 2048) synchronous master clock of SDTrans384 with your Buffalo II?
Bunpei
ES9018 chips in Accuphase DC-901
Close-up photos are shown on the site;
Wizard High-End Audio Blog: More pictures of Accuphase DC-901
Two ES9018 chips per channel, 16 DAC modules for one channel!
One 40MHz master clock oscillator per channel.
An ES9018-based DAC, CAPRICE by Fidelix is bringing up a mood of reappraisal of DSD sounds in Japan. The DAC offers an option of raw DSD signal input and I heard that at least two famous audio reviewers in Japan purchased CAPRICE with the option.
According to Functional Block Diagram in Product Brief document of ES9018, it seems for me that DSD signals are converted into PCM at the stage prior to oversampling in ES9018. This approach seems quite different from such DAC chips, TI DSD1702 or DSD1608 that has a dedicated DSD filtering signal path.
How do you feel about this point?
Hi, I think I read that 9018 DSD is not converted to PCM in this thread. Can anyone confirm that DSD signal is not converted internally in ESS 9018 ?
Best
Good news to those who wanted to see the ES9018 DAC datasheet!
I spoke with Bryan at Shaw Electronics (shawelectronics.com), the US distributor for the chip... he said that 6 months ago the ES9018 datasheet was taken off the non-disclosure agreement list, so now you just have to request it and he will send it to you.
So, if you want the ES9018 DAC datasheet, kindly email Bryan at "bryan at shawelectronics dot com" and ask! 🙂
