ES9039Q2M S/PDIF DAC design
Should i turn off the analog output of the DAC before changing/applying new filter settings or something else ?
Register 0: SYSTEM CONFIG
Bit [1]
Enables the analog section of the DAC.
• 1'b0: DAC disabled (default)
• 1'b1: DAC enabled
In what cases is it necessary to turn it off?
Have tried I2S without masterclock. Two cards. 10k output to both cards. One input to ADC left ch, the other to ADC righht. They are in sync with no phase drift.
So guessing at least 1us timing stability between cards.
Agree that it must be that stable.
Source has the channels synced and determenistic timing
