Ebay cheap TDA7498 boards
It's very simple:
-this Particular Booster already has a 2.1x5.5 mm DC Input Jack, so you can just plug your Power Adapter in there
-the output terminal(labeled "out") can be wired to this DC Plug DC Plug on aliexpress, which can be directly plugged into your board.
Theres one Blue Potentiometer(v-adj) to adjust the Voltage, you need a Multimeter to set it to the voltage you need. The Other Blue Potentiometer is to adjust the maximum Current, it should be set to max.
Here's a youtube review about this particular step up converter:
600W DC-DC Boost Converter Review and Play Around (This one's a keeper)
Distorted datasheet values look close enough to 30 watt.
My experience with all three types of TDA7498 boards i have used is that they work great with anything from a 19v laptop brick up to a 36v smps (meanwell knockoff).
Two 12v sla batteries gave me the most satisfying results.
But i had a 19v laptop brick that wasn't able to drive the board.
Voltage broke down completely when poweing the amp up.
That might be because of the 4700uF chemicon kzn i put in front of the power input....i do not know, just a possibility.
