Eagle question
I think there should be a small 'target' cross somewhere in the text field that is the attach point for the cursor.
Generally, all objects, be it a text block, a part footprint or whatever, have an 'attach point', normally a cross, which attaches to the cursor if you click on it so the system understands what object you want to manipulate.
Jan
I´m having a harware meltdown in thinking.
When I messaure the current through the resistor(s).
Do I messaure ONLY over the R2 resistor OR do I messaure over the resistot AND the trimpot? 😕
I made test point on all boards like this:
attachment.php
I am goint to solder an U shaped solid wire to the 2 pads so that I can attached the messauring pin to.
These boards will be rather small 6x3cm allmost to small....😎
I have ordered the boards..
