I've tested a whole load of high mu triode strapped pentodes. Try searching for "gm70 driver'
The 6j9p is capable of heroic performance if you run it hot
I believe these tubes can run a2 with little grid current demamds allowing huge voltage swings. The more current you run through them the lower the distortion, certainly much lower than a 5687 or 807. My tests were done with mosfet loads, best were gyratory.
I am not sure that E180F are very close to 6j9p with CCS the E180F run at 200v and 16mA -2v red diode, far of the curves of the 6j9p now I alternating the E280F and E180F both -2v at 16mA with single 10m45s the wave square are very good in both 20hz to 20khz a little bit better the Tesla E180F
That's the same kind of bias 6j9p's run at. Infact many hi mu triode strapped pentodes have the same pin out and will work well at that bias, d3a ef184 6j52 etc etc as long as you strap both g2 and g3 to plate you can just roll all these tubes as some have the grids on opposite pins.
Sound wise I preferred d3a but none of them were duds. And all measured better than any small signal 9 pin tube I've tried with the exception of the 6c45pi
What Mu has the 6j9p? I drive the 211 with only one stage the 6j51p do perfectly only is a little dry.. The ef184, e180f and e280f are in the limit but is true that the e180f e280f have a pretty sound and I dont need a lot of watts.
Enzo I thought the same to strapp all g2 and g3 to plate and you can play with all.
I am finishing all measures with the oscilloscope, my new toy for Christmas, not very good at the moment maybe need to replace the chinese OPT
Hello !
May be this one would help ...
Thanks Ciu
I had high hopes for the 6j9p-e as I hoped it would have the same linearity but a higher power anode to allow the 30ma or so that the 6j9p likes but can't sustain thermaly. I found it disappointing.
I have some 6j51 coming and some 6j11 in a box that I haven't tested yet. Was thinking of using these in a 6cb5a se or pp amp. I use 4p1l as drivers in my dht amps
6j9p Gyrator load 67vrmS 210v 24ma 0.048% jaw dropping surely?!
[/URL]i had tried Gyrator loaded 6J11P-E with 170v on plate to drive my 6C33CB Set.Utracer results for E180F and 6J11P in triode.
I consider the 6J11P closer to E180F than 6J9P, but harder to find these days.
Gary
Had a good performance and very quiet.
Why?3rd grid to cathode.
Connect it to plate and get higher gm and lower rp.
Joined 2009
Is that a benchtop power supply you've made that I can see in the back there for your R&D, it looks interesting ?View attachment 1105890
Hello,
3 6j9p on the bench,triode strapped
B+=285v
Ra =12k
Rk=100Ω,no capacitor .
100Ω screen resistor.
Ia= around 12,5 ma
Gain = a little more than 30.
It will use for input stage like this,no ccs.
Cheers.
Yes it is. It is not so difficult to build and very usefull.Is that a benchtop power supply you've made that I can see in the back there for your R&D, it looks interesting ?
Joined 2009
Don't want to drag this thread off topic but have you some design information and experience gained (why did you go for this design and what did you learn that will help me avoid learning from scratch?), for your bench supply posted somewhere as you're photo above has now tempted me to build a supply for myself ?
Look at this: https://www.diyaudio.com/community/threads/hv-tube-bench-power-supply.282450/post-6716146Don't want to drag this thread off topic but have you some design information and experience gained (why did you go for this design and what did you learn that will help me avoid learning from scratch?), for your bench supply posted somewhere as you're photo above has now tempted me to build a supply for myself ?
Why?
I will do the trial next time,but will the tube wear out faster?Why?
- Tubes / Valves
- E180F triode-strapped.
