I have cutted the pcboard..i found that we cannot use L shape adaptor
to high power...so...if this amplifier is able to put out 300 watts (distorted at 2 ohms) you should install your power transistors directly into the main heatsink avoiding L shape adaptor
regards,
Carlos
regards,
Carlos
I am suggesting my people to cut the board (saw) this way
My mistake not to forecast this stuff before.
Since the Supercharged, and them the Dx Blame MKIII and some other models...Dx Blame ST included...i was already cutting this piece of pcboard off...i cannot understand my dumbness.
regards,
Carlos
regards,
Carlos
Dx Super A - Brazil - Layout Zimmer
Dx Super A Brazil Layout Zimmer - YouTube
Made in Brazil.
Carlos
Made in Brazil.
Carlos
Dx Super A - Brazil - Layout by Zimmer
Very nice white boards.
With the time passing by, it will turn yellish...and this is what i want.... the colour of Coffee with Milk..something very brazilian.
regards,
Carlos
regards,
Carlos
regards,
Carlos
Very nice Carlos! But Why didn't you put the heat-sink on the other side. I think the way you have it now will not dissipate heat too easily since there is a small thin/short blade holding ALL the transistors. I think it should be better if all transistors are mounted on the bottom (thick side) of the base of heat-sink. I hope I get myself understood...😱
I'm in a progress of update Dx Super A with a "no L shape" do not worried I still have the original gerbers from the original first design in case people like the first version still but here is guys I have to check if all is correct before, here is a print out just to see how it looks . 😛
Juan
Juan
I have tested Lanchile.... this way is a little bit worse
Just a little...but this is a very long story...a video explains this in portuguese only.
Here you have....give a try to see if you understand me:
http://www.youtube.com/watch?v=5A0R9SLuj_I
This way is better to me, then i can install two amplifiers along the enclosure and pump air from the upper case....another long story.
regards,
Carlos
regards,
Carlos
Nice contrast. White and black, the components should be gold 😀Dx Super A Brazil Layout Zimmer - YouTube
regards,
Carlos
kind regards,
Harrison.
Heheheheheh.... good idea.
I am in love with Black and White pcboards since i saw a Technics from the eigthies.
regards,
Carlos
regards,
Carlos
Juanito..... having time, please send me gerbers to my files
This gonna be the standard pcboard layout from now on.
We are reducing the Brazilian layout too...transistors must go directly into the heatsink to increase thermal transference.
That lost pcboard the brazilian complained, have arrived from Puerto Rico, 186 days latter...but arrived...the man is transfering the money to your account.
regards,
Carlos
regards,
Carlos
Wow that is amazing ! I never thought that his boards arrive a few days ago is a miracle I'm really happy he got them "late" but he got them man this is special for me I know he will enjoy that nice sound notes I still using my Super A inside the car amplifier chassis looks great! Carlos I'm going to send you the gerbers today let me check to make sure is symmetrical correct 😀. this is Super A Amplifier of Steel . 😛
Juan
Juan
Yes....may sound metalic
At the end it is a steel Super A.
This one (picture) may be the heatsinker..... all heatsink... a high power prototype... plus and minus 90 volts.... or aluminum
regards,
Carlos
regards,
Carlos
Last updates on Dx Super A
Now that we have made the board even smaller, now we have copper track reinforcements for better current travel into important areas, I hope you guys like this 😀 .
Juan
Juan
Strong emotions for you..... do you have good amplifier and speakers
connected to your computer?..... then turn the volume all the way up.
regards,
Carlos
MY DIY STEREO, DX BLAME ST, AIKIDO - YouTube
regards,
Carlos
- Dx Blame ST together Dx Super A
