Easy when you know how - where to start?
I started here.
https://hifiduino.wordpress.com/introduction-and-guide-to-hifiduino/
For my AKM build I only use a £5 Arduino, no display, encoder, remote etc. to basically write the values I want into each register.
Sent from my iPhone using Tapatalk
Does anyone know if the AK4497 also needs 7.2V for best sound in Avcc ?
Don't think this is rated for 7.2V but best check the datasheet.
https://www.akm.com/akm/en/file/datasheet/AK4497EQ.pdf
Max recommended in the datasheet is 5.25V with an absolute max of 6V before damage.
Unlike the AK4490, the AK4497 datasheet doesn't specifically mention that output voltage is dependent on the input voltage. Would probably be best just to go with the usual 5V.
EDIT : Did a double check, my mistake, looks like output voltage is still dependent on the input voltage. Given that the max recommended operating voltage is 5.25V tho, there might be only minimal gain in cranking up the voltage, unlike AK4490's max voltage input of 7.2V
Hi guys,
I too am trying my luck at an AK4490 DAC. I have a basic design down and am waiting on prototype PCBs.
I see that many of you are using Arduino UNOs to program the chip.
You do realize that you are using 5V TTL logic to interface to a 3.3V part, right?
From what I am reading the 4490 seems to be tolerant to the 5V of the UNO, but I wouldn't keep doing that for long.. Level shifters are a dime a dozen.
Better yet, I would go for an I2C isolator.. That way I would do both galvanic isolation and level shifting with one part.
Hi guys,
Have had no issues with applying 5V I2C to many 3.3V DAC chips including AK4490 and ES9018S, all working fine after many years of use. YMMV
I know for a fact that ES9018's I2C lines are 5V tolerant (it is stated in the datasheet).
Perhaps AK4490's I2C lines are also 5V tolerant, but it's an undocumented feature.
Dimdim
we are also starting design on a 4490 for RPI. I almost have half a mind to open the design to the community.
Hi guys,
I think that an ak4490-based DAC would be a great match to an RPi & Kali combo and such a community-designed DAC would be at the very least an interesting implementation.
The only problem with a HAT sized ak4490-DAC would be the constraints of the HAT size. It would mean that a cost-no-object design would basically be out of the question. On the other hand, not everyone would desire a cost-no-object design.
Well I have a few ideas already ... I think that HAT size is possible for a single DAC IC . Yeah I know about those elec capacitors on AVCC
Let me talk with our team ..
If you are discussing this item open, I would be very interested in "cloning" the design to an Ordoid C2 variant for personal use.
Related to the DAC design itself, maybe I could support you in PCB-design issues.
Ok we can open most of the design. (not gerber)
I also think that we should bring only one power supply to the board and generate everything from there..
Choices:
1. Should it be master or slave
2. How many voltages are needed..and what value (important)
3. Summing circuit..(choice of opamp and voltages)
Choices:
I think you should see thisOk we can open most of the design. (not gerber)
Choices:
http://taudac.com/#av_section_2
And this
http://terratechnos.com/products/terraberrydac/
Enviado do meu SM-J500F através de Tapatalk
This is minimum 700Eur DAC
I was thinking for a target price of less than 150Eur
Yeap I am aware of this design...I was thinking something along those lines.
Hi guys,
a simple question , the single-chip AK4497 be ready for sale? where to buy it?
Digi-Key has them!!!
AK4497EQ AKM Semiconductor Inc. | Integrated Circuits (ICs) | DigiKey
I have a dual-mono AK4497 DAC kit on its way to me;
AK4497DM DAC??
(I use Google Translate)
I will need to derive a single-ended signal from the DAC outputs (voltage output so no I/V required). I have previously had good results using a Broskie BCF on the outputs of a AK4490 DAC (single) and that remains an option (though the BCF has been out of stock for a long time)
However, as this new DAC is dual-mono it is a slightly different scenario as the DAC outputs need to be summed, here's the relevant datasheet schematic;
Instead of using the 100uF cap and 10K/44R resistors, I'm wondering if I can simply connect the relevant DAC outputs together (to sum them) and feed the differential signals into a suitable transformer to derive the SE signal (I'm assuming the roll-off of the transformer will double up with LP filter duties too). Even better would be to use my Silk TVCs as the transformer.
The plan is to pass the SE signal to a 4P1L tube buffer stage.
Thoughts/comments?
Cheers
Ray
AK4497DM DAC??
Thoughts/comments?
Cheers
Ray
Those resistors and caps *are* summing the outputs. Each summed output is fed to an LPF - so yes, you can use a transformer instead of the two opamps. I would not eliminate any of those components. Ensure your transformer Rdc does not form a high pass filter with the capacitor and cut your low bass off, you can increase the cap without penalty.
You can also use only one polarity of output, this will change the characteristics of the sound to include more second order HD which theoretically degrades THD. You could also try dual primary windings, with the transformer doing the summing. Experimentation is key to getting what you want.
The primary winding will be fed by the two junctions of the 44 ohm resistors, that are currently connected to the opamp + inputs (the 22 ohm resistors can be ignored).
- Digital Line Level
- Dual Mono DAC AK4490/AK4497
