Dual 701 turntable assembly problems
Well here I am in a similar pickle. I disassembled my 701 to clean and lubricate the motor shaft and bearings on the sub platter.
When I re-assembled, the turntable is now in a constant return cycle (the cam gear keeps turning). Also the tonearm is not moving correctly at all.
I was pretty careful, and I'm confident that I have the ball bearing back in place correctly - and that the cam follower is in the right place. I don't know what is wrong. I have stared at the mechanism and looked at my photos and read other posts here. If any of you guys have any suggestions I am all ears.
I am pretty fustrated at the moment. Many thanks.
With due respect, I don't think so. By 1972, when the 701 emerged into the market, Dual was one of the biggest TT manufacturers in the whole wide world, if not the biggest at all, and had some huge amount of experience with automatic TT's and record changers. The definitively didn't need to »fiddle« around with something.
Yes, mechanical engineering is actually a thing.
I got it. The tang end of one of the levers was hung up - almost like as shown in this photo from earlier in the thread.
Anyway it looks like back I am back up and running. Now to do some listening tests..
Oh man.. I played one side of an LP. At the end, it properly cycled off - but when the tonearm set back down on the rest, it began lifting up and setting back down repeatedly. Now it is just doing that in a non-ending loop.
So something must be out of place in the linkage I'm thinking at the cam gear.
I hope to be able to take a look at this later today. So frustrating!
My first piece of advice is not to get too frustrated otherwise you lose the ability to think and act rationally.
The second thing that comes to mind is that little metal ball that the OP lost (if I remember correctly), and may have done the same there.
Look carefully at the photos because they seem to highlight just what (and how) is needed.
I was way ahead of you ulogon. I took a couple of days of not looking at this at all.
Now I am ready to take another stab at it. I'm pretty sure the ball bearing is correct. But I can't say with 100% certainty.
I am a little suspicious of that tiny little spring - I may not have it attached correctly. But I don't find a good illustration of how it should be.
Anyway this is what mine is currently doing (video link below):
https://www.dropbox.com/scl/fi/y6wp...ey=nh8im2q7yotl9pw3734g3h000&st=nzufrvjg&dl=0
Thanks to all. Now automatic seems to work with a new copper friction plate, but now I have this problem;
When using arm lift, the arm raises to desired height with a little headroom/slack above.
When automatic raises the arm, the arm is pressed all the way to max, creating a lot of friction? The lever arm controlled by the cam wheel is adjusted, so it's just lifts the control stud (steuer pimpel) 1 mm. Picture below shows the arm, when it's pressed all the way up by automatic.
Any ideas?
Hi All. The never endning story continues......
Got almost everything adjusted and working (after changing a broken pos. 61 (part no. 218 318) "Positioning sleeve" which caused the tonoarm to lift to absolute maximum creating huge amount of resistance during automatic tonearm movements). Fixed now!
However the small ball pos. 165 keeps faling out of the groove of the "Shut-off slide" pos.164 when turntable is tilted heavily. I know this kind of tilt is NOT practice during normal use, however it could happen during transport! I see no way how to ensure the ball stays in place without bending the Shut-off slide out of shape??? Any good ideas?
