Douk EL34 Amp kit
312 with input tube in right socket 335 with input in left socket 308 with no input tubes in either socket
Measured to ground from pin 4 EL34?
I don't see how the voltage can be lower out of the 10K with no tubes in the input sockets?
The input tubes draw current from the 10K and the voltage drop should increase so the voltage on pin 4 of the EL34 should go down..
M. Gregg
