Doug Self's New Preamp Construction and Pictures
More.... Input PCBs with ribbon cable and some custom 2-pin interconnects.
Redjr, may i ask about the ribbon cable and connectors you have used?
Ideally, i would like to have a similar set up as yours with the Left & Right input pcb's, one above the other.
What connectors and cable have you used to connect the two K17 sockets together?
This cable then connects to K1 on the Front Panel pcb.
I have finally been able to get back to this project build after so long.
Can anyone please give me any advise and steps that i should take and be aware of when doing the wiring?
Are there straight forward guides available of all the connections, including the d.c. connections?
With thanks
Calpe
My build
My very slow build up to now with just paper labels indicating controls...
Wiring to do.....
Did you notice the Harwin connector housing has pin 1 marked with an arrow. Just make sure you follow the same wire pattern on each end of the cable. Most of the connections from one board to the next is pin specific. The silk screening on the board will guide you.
Dennis plz see your P.M.
Just to mention to the late builders (like me) the NE5532's that were available when i purchased them were the NE5532AP.
http://uk.farnell.com/texas-instruments/ne5532ap/op-amp-dual-low-noise-5532-dip8/dp/1106091?ost=NE5532AP&ddkey=http%3Aen-GB%2FElement14_United_Kingdom%2Fsearch
You'll see here the supply voltage range is +5v - 15v.
The Elektor project has 17v supplies from the PSU.
In the above technical sheet for this i.c. it shows max. voltage is 22v, but recommended supply is 15v.
I wrote to Elektor explaining this and they told me to play it safe reduce R2 & R4 from 1.3k to 1.1k, which i have done, reducing the PSU o/p from 17 to 15v.
I'm playing it safe.
In Elektor 06-2012, page 26, it give information of 'Miscellaneous - Not on PCB'.
Can someone clear up what is written of the fuse F1 (230VAC) = fuse, 0.315A Antisurge?
What is the correct mains input fuse that should be used on the mains input circuit?
