Does this explain what generates gravity?
Not sure why but I thought about coherant light...
I'm not sure why you thought about coherent light either. :scratch:
What is your context?
One of the optical problems with turning light into a beam is the size of the source. In the case of laser diodes this is rather small which allows a fairly decent narrow beam of light to be produced. A LED can't do the same thing and the light isn't coherent.
When said beam hits something it heats up. The degree depend on power. Suppose I am wondering about the mechanism that causes that,
It is in a sense as gravity effects it, Gravititational "force" from an object falls as distance increases 😉 reach zero though? Interesting question.
When did gravity form? All "Matter" is said to have appeared in an incredibly short period of time. Gravity? Pass but taking typical info such as
A few minutes into the expansion, the period known as Big Bang nucleosynthesis also began. Thanks to temperatures dropping to 1 billion kelvin and the energy densities dropping to about the equivalent of air, neutrons and protons began to combine to form the universe's first deuterium (a stable isotope of Hydrogen) and helium atoms. However, most of the Universe's protons remained uncombined as hydrogen nuclei.
After about 379,000 years, electrons combined with these nuclei to form atoms (again, mostly hydrogen), while the radiation decoupled from matter and continued to expand through space, largely unimpeded. This radiation is now known to be what constitutes the Cosmic Microwave Background (CMB), which today is the oldest light in the Universe.
As the CMB expanded, it gradually lost density and energy, and is currently estimated to have a temperature of 2.7260 ± 0.0013 K (-270.424 °C/ -454.763 °F ) and an energy density of 0.25 eV/cm3 (or 4.005×10-14 J/m3; 400–500 photons/cm3). The CMB can be seen in all directions at a distance of roughly 13.8 billion light years, but estimates of its actual distance place it at about 46 billion light years from the center of the Universe.
Well is definitely did when atoms formed. Clearly gravity still ruled over expansion as stars etc formed but inflation continued. What effect does that have on what might be called local time in various places in the entire universe? Time doesn't appear to be constant over the entire universe. It can't be.
Enter sort fo 3D cobwebs of dark matter that for some reason doesn't attract itself but does attract hydrogen. Suppose that fits if it's denser. 😉 Maybe it forms black holes. The other question is how was it formed?
The universe is expanding and it’s accelerating. Star formation peaked between 7 and 9 billion yrs ago. The question Id like to get answered is has the expansion rate changed , or has it been constant?
Great picture, but: the driver does see the same!
a) images only! b) mirrored images: cancel each other out!
No special and general relativity of Einstein!
No "spacetime", that does expand, or is curvable, bendable, stretchable...-)
Doppler effect only;-)
Now you finally got it;-)
Just when I thought this Thread can't get Worse. It gets Worse!
OK, 4 ;-) winks from @cumbb is not his record. I recently recorded 5!
The most difficult book I have on loan at the moment is Songs of the Dying Earth:
I have returned it to the Library 2 times. But have taken it out again, which I think is called Masochism. Frankly it destroys my already fragile mind with its Weirdness.
TBH, I find the Feynman Lectures on Physics easier.
I wonder if @cumbb is related to Mazirian the Magician:
https://en.wikipedia.org/wiki/Jack_Vance
Some entities are best avoided. I think @cumbb should be sectioned for a VERY LONG TIME. It might be a kindness. 😉
There is no absolute certainty that the expansion of the universe is accelerating.
Some physicists claim that the original evidence for accelerated expansion is, at most, 3-sigma.
This is far short of the 5-sigma standard required to claim a discovery of fundamental significance.
There is a problem with the current size of the database, but that is getting larger as physicists work on the problem.
I suspect heat will be generated if atoms or molecules are energised enough to re-radiate incident EM radiation in the infra-red region. Interesting thought though is what happens when you shine an IR lamp on your skin. Clearly your skin cells are re-radiating at IR so that’s why you feel warm. Or is it because molecules and/or atoms are just jiggling about, to use Feynman’s favourite expression?
Or maybe in a lasers case bombarded with massless wavelike particles. In any case lasers like light sales are instances where light produces energy. IR lamps are more like electric fires. A laser - doesn't seem to matter what the wavelength is.
Conventional lasers are a little like true light clocks base on transit time. Gavity changes wavelength but also changes time, In a lasers case frequency matters.
Reactions: Bonsai
@Bonsai
I could only comment on your initial statement because I did not fully understand the premise behind your subsequent question.
Einstein's field equations permit three possible scenarios for the rate of expansion of the universe, based on the assumption of its isotropy.
An accelerating expansion is not one of those three scenarios, but requires a positive value of the gravitational constant, AKA dark energy. It is now postulated that at some point in its history the universe started to expand at an increasing rate (5 billion years ago according to Wiki).
Did you think that this point coincided with the peak in star formation that you mentioned?
Galu, IIUC, peak star formation occurred between 7 and 9 billion yrs ago, but quite how this might feed into an accelerated expansion starting at 5 billion yrs ago I haven’t worked out. You have an expanding universe (so time is ’stretching’ anyway) and further, would there be a delay due to the timescales involved before it contributed to observed accelerated expansion? I don’t know.
Bonsai, you have no idea what you are talking about.
Watch this video about "Firefly" if you please.
As an Autistic person, I naturally admired "River".
Unfortunately I was also drawn to Saffron.
Bit of a looker, you might agree. We all make mistakes. Kaylee would have been a better choice, but that is hindsight. 🙂
It all seems to be based on distant s1a supernovas. Standard candles. I'd like to know how they obtain a sigma for any variations in their brightness. One attempt - it leaves me wondering what the paper means
https://www.aanda.org/articles/aa/full_html/2018/07/aa31425-17/aa31425-17.html
I can provide more information on how the two events relate in time.
Accelerating expansion is said to have begun when the universe entered its dark-energy-dominated era.
This era was proceeded by the matter-dominated era.
Peak star formation occurred towards the end of the latter era, as shown in the attachment.
Reactions: Bonsai
