Do all audio amplifiers really sound the same???
Andre Visser said:
Please give us some tips, I would love to have one.
André
How about a used Pioneer SX-1500 . Seems to work as good as anything else.
john curl said:
Schumpe's experience is very much like my experience with red wine. Just give me something 'acceptable' to drink and I am happy. [...] I will stick to the cheap stuff, why pay more?
That comparison is a little off, as far as I'm concerned. To me it seems more like somebody wants to tell me that wine tastes different if I open it with an expensive cork screw. I am not happy with "acceptable" sound, I just don't think you can improve anything on the amplifier side of things.
Cheers
schumpe said:
[snip]To me it seems more like somebody wants to tell me that wine tastes different if I open it with an expensive cork screw. I am not happy with "acceptable" sound, I just don't think you can improve anything on the amplifier side of things.
Cheers
Indeed, well said. But, you know, if you use that rare corkscrew you won at the antique auction, the wine is bound to taste better 😉
I know, I know, *you* don't need convincing..
Jan Didden
wakibaki said:
Where do you think the good engineers interested in audio go? They get snapped up by (or even start) the companies that make chips like the 3886 or Tripath, but the majority are not interested in audio, other than digital audio.
That's where anything exciting is going on, design at chip level.
Yet another anecdote from the tiresome Peter-Pan.
I have heard a signal looped thru a good soundcard and the same file looped via the soundcard and a LM3886 amp (single chip) working into a complex dummy load at aprox 1W.
I could not detect the amp. I listened blind (yes I have done some of those blind tests).
Then I listened to three other amps tested the same way and those could not pass the signal without coloration.
Class D amps (which I have not tested) seems to have coloration in the topoctave which makes them non-transparent. People seems to like them anyway and I guess that's ok! 🙂
/Peter
wakibaki said:
Yes, that is precisely what I am suggesting.
Pretty soon there won't be much left to do there.
I told you already, audio amplifier design is dead. Moribund would be a more accurate description, but I'm trying to get people's attention. A lot of what is being done now was worked out years ago, just implementing it was a materials and fabrication problem. It's trivial to design a fully digital 24-bit resolution PWM DAC in VHDL, you just can't get chips to run fast enough.
I know, I thought I'd made my fortune until I did the calculations.
w
I've said earlier, if you rate a 3886 as hi-fi, we have different meanings for the word hi-fi, there is so much more.
Don't know where the DAC came into the picture but why must it be PWM?
cuibono said:
What is this?
You insert the DUT in the playback chain and see if it can pass the signal without being detected. This is done blind and if you can't detect when the DUT is in the chain or not one cold argue it's good enough for that particular set up, those ears and the music/signals used.
Makes more sense than A/B since you don't compare the DUT to something else but against itself sort of.
When testing an power amplifier a complex dummyload is connected to the output of the amp.
It's not the only way but one of the best ways to test transmission links.
You can either listen live or record material looped thru the DUT and listen back later. This way files can be shared over the internet for testing by others.
/Peter
john curl said:
As I previously said, IF all amps sound the same, then look to your speakers and/or your sources. What is wrong with this?
Well, I think we can all agree that the difference between speakers will be greater than the differences between amps. There is NOTHING wrong with that! (I won't comment on sources--I'll leave that for someone else to tackle) However, you bring up a good point: different amps are designed to drive different loads, meaning that changing the speakers/loads will change the behavior of the amplifier.
This comes back to the question of why we build different amps, but for some reason we seem to be glossing over that fact: amps capable of driving a similar load within their operating range should sound very similar! There may be a difference in clipping response, or behavior outside of normal operating parameters, which is, IMHO, what makes the difference between "good enough" amps and "really good" amps. The latter handle the extremes without strain, resulting in a qualitatively "better" sound when operating close to or beyond the capabilities of the "good enough" amps.
Therein lies the rub! The "all amps sound the same" argument assumes that we don't approach those limits where the really good amps prove their worth.
Someone made fun of the LTS test earlier.. something about only bats would hear a roll off of a few tenths of a dB at 10kHz.
The following is from a BT I participated in on a LM3886 amp. RMAA measurements.
Summary
Frequency response (from 40 Hz to 15 kHz), dB +0.04, -0.42 Good
Noise level, dB (A) -93.4 Very good
Dynamic range, dB (A) N/A N/A
THD, % 0.0011 Excellent
THD + Noise, dB (A) -85.4 Good
IMD + Noise, % 0.0085 Very good
Stereo crosstalk, dB N/A N/A
IMD at 10 kHz, % N/A N/A
General performance Very good
The roll off is because a slightly to big RF cap is used at the input. The designer liked it that way. I listened blind to the soundcard loopback and compared that to the loop including the dummyloaded LM3886.
This small roll off could easily be heard. Once he changed the input cap to a smaller value I could not differentiate between the soundcard loop and the LM3886 loop.
I used a Echo Audiofire4 with HD600 as monitoring tools. So for me 0.4dB at 10k and 0.8dB at 20k was easily heard.
/Peter
Sure, you will need VERY good speakers to make any use of the best amps...nothing is better than its weakest link
A "better" amp wont "help" any avarage speakers, only a different amp may do so
Well, I have already said more than I like to
Good luck🙂
That's the way it is and for some types of colorations a low resolution speaker can mask enough to make it inaudible even though it is audible on a high resolution speaker.
Well.. no, not if they are not well designed.
The resolution even at a watt or two differs between most amps.
/Peter
pinkmouse said:
Could it be that left brain/right brain theory is based on incorrect assumptions about how the sensory mechanisms of the brain operate? 😉
It's a nice story, and one that fits in well with the way we imagine our world to be, but despite being quoted in lots of pop science, management training, art tutorial books etc. etc. is still far from proven, and a gross simplification of the experimental evidence.
PM,
I think you'll find the current research supports the idea of left/right localisation of brain activity and also identifies specific regions activated by listening to music.
This is a quick trawl of science daily turned up these reports for instance:
http://www.sciencedaily.com/releases/2007/10/071027102409.htm
http://www.sciencedaily.com/releases/2007/08/070801122226.htm
http://www.sciencedaily.com/releases/2007/11/071104191553.htm
http://www.sciencedaily.com/releases/2008/02/080226213431.htm
And for those who argue for influence of price tag on perception of quality, you'll enjoy this article...
http://www.sciencedaily.com/releases/2008/01/080126101053.htm
cheers
Paul
/Peter
Different loop bandwidth, different impulse. You heard much more than half a dB difference.
Hi Peter,
Could you describe the test setup a bit? I'm assuming there was a pot or attenuator somewhere in the loop to set the gain of the amplifier path to 1. Is that correct? If so, where was this pot located? I'm thinking that if it were at the amp's input, that would reduce the cutoff frequency of the amp's input LPF.
