diyAB Amp The "Honey Badger" build thread
Hi to all, just a small question regarding the zener diode in the amp, at the moment of my purchase for parts the 1n4744A was not available so I choose another type, BZX85C15-TAP, I have read a bit today and because of the different current that these have it might not work ok in some circuits, is this the case for the HB? The was in the BOM is now available, should I remove it and order the 4744A and resolder?
Thanks,
Florin
Thanks,
Florin
Just omit the Zener. It is only useful at clipping. And I think the best choice is BAV21, not 1N4744A.
Gesendet von meinem D5803 mit Tapatalk
Hi, if I omit that what will be used for the cascode reference? According to the build guide this design provides the best solution. Maybe I wasn't very precise about what diode I was talking, it's the one one in Cascode / Current Mirror Q3 and Q4. Thanks
Oooops, sorry, my bad. I thought it was the Baker clamp.
I guess the voltage reference should work with most Zeners as long the voltage is right.
Here is the basic circuit ... only have to select transformer .. resistor & scope scale....
there is always a curve.
It start with a steep slope. Then curves around to be come a much flatter slope.
The flatter slope can be used to determine the dynamic impedance.
The higher the current the lower (flatter slope) the impedance.
beware of zeners .... some have weird bumps aroud the knee region ... in a low current application it may have a strange effect
where is the evidence for these statements?
The higher the current the lower (flatter slope) the impedance.where is the evidence for these statements?
There is no proof ... only my words ... at the time I did not take pictures .. but I did see .. I made a sketch .. see it below ... the difference betwen 2 ... 20 Volts zener from different company ..
Hi Andrew,
I've used curve tracers to characterise zener diodes. Unless you dynamically sweep the component, you would never see the anomaly. I haven't noticed the kink in the curve, but that doesn't mean that the kink doesn't exist. I have seen some really soft knees and running a zener at low current (for the voltage). This is undesirable for obvious reasons.
I try to reach a happy spot where power dissipation is minimised, but high enough so that I'm away from the knee. It's a balancing act with high voltage regulators.
-Chris
Is your "bump" related to ringing / resonance / overshoot with the transformer in your test setup? A bit like rectifier diodes switching on/off the current, which triggers oscillation in the transformer.
Hi All. I am a little confused when it comes to the inductor for this board. The schematic and build guild calls for a 1.5uH inductor made from 18 Gauge wire 12.5-15mm Diameter 14-16 Turns.
The thing is I made this then tested / measured it inductance using my oscilloscope.
I followed a YouTube guide from a reputable guy that shows how to measures inductance. I tested out his method on a small inductor that I had at home. The testing method and my calculations yielded the correct resulting inductance.
I am however not able to get anywhere close to 1.5uH with the numbers shown in the guide for the inductor.
I was about to get a inductance of 1.5uh but with only about 4-5 turns
The Youtube guide that I followed was
https://www.youtube.com/watch?v=74fz9iwZ_sM
L = 1 / ((2 x Pi x F ) x C)
F = 4.115Mhz
C = 1nF
Any help or advice on this would be appreciated.
Attached are some photos.
