Mine has even more caps in the PSU!
Rail voltage is abot +/- 40 VDC only in mine. Works great, though!
Really nice finish with impressive heatsinks. Why only +/-40VDC and so huge PS capacitance?
I have +/-63VDC to get better headroom and only 6x15,000uF. Works fine as HB is a good design.
cheers,
cheers,
I had a large box full of capacitors that won't like anything higher than 60 VDC, so I had to stay at lower rail voltage. Not a problem, since I don't need to go very loud.
Otherwise, it all boils down if you want to drive high impedance speakers (use higher rail voltage, but compromise on max. output current) or low impedance speakers (use high max. output current, but compromise on rail voltage).
Hi Matthias,
didn't you tell me you've ordered 35-0-35 Vac transformers? So, did you measure rail voltages of 40 Vdc under full load?
Best regards!
Could well be that my rails are closer to 45 VDC. I don't remember from the top of my head. I'd have to take the lids off to check in my amps.
Nice.. My rail voltage is about +/-, 55 volts DC, hence I used 80v caps at 10kuF each. May I know what preamp you are using? Would an active or passive preamp be better?Mine has even more caps in the PSU!
Thanks OS for such a good amp design. Many of us owe you this big TQ. It is indeed a great amp.Best Badger yet. Very nice output stage implementation.
VERY ample PS , too!!
OS
Active. Read "Small Signal Audio Design" by Douglas Self. Douglas explains all the nitty-gritty of preamp designs.
cheers,
I have a transformer volume control that couples the output of my DDDAC to the input of the Badger. That is clearly passive, but it's not the usual "volume-pot-without-a-buffer-passive". I am not a fan of "passive volume pots" because the impedance matching is almost always an issue. A transformer (passive) or buffer (active) is required in my opinion.
cheers,
Thanks.. wow 577 pages.. lol..any DIY active preamps which I can build myself without going thru entire 577 pages.
what is a transformer volume control?
I am using a Sowter 9335. Since my DDDAC really needs a transformer at its output, I figured I could combine the transformer with the volume control. Otherwise I would have use a normal volume pot + buffer.
Hi, are there experiences with HB and Quad esl?
I am planning to build a HB to be used with esl 63. Those speakers short the AMP output if a spark is detecteert by an antenne to protect the loudspeaker. An electronic lighter naar the speaker is sufficiënt to provoceren this.
There has to be some kind of current protection, I know that OS does’nt likes current limitting but properly designed it is like clipping. Nobody likes clipping but it protects.
An other option seems to use a switching powersupply, current limit build into the supply as well as softstart.
Any ideas about these?
Nico
Nico
Hello . I can ask you some beginner questions: I took up this project again, taking a long break, my idea and building a Honey Badger suitable for pushing 3-way boxes like my Ekta Grande (4 ohm). I intend to recycle psu components of Aleph 2 that I owned. I have 2 toroidal 600w 2x37, can I make a dual mono or e too 600w x channel? x PSU I have 16 cap Kemet from 47000uf 63v, a pair x channel okay? or better than more? ..x testing of H-B. and the next projects, a friend recommends me to buy a variac, and correct? thank you
Hi All,
I'm in the process of ordering parts for an HB build. I plan to use the SMPS that OStripper linked to a few months ago. (The SMPS500R from Connex Electronics +/- 60V version).
Questions:
Is there anything I need to change in the amp circuit when using that power supply?
The system will be: Source > Glass-ware's Aikido 12VAC preamp > Honey Badger > Magnepan LRS speakers (4 ohm)
Any advice would be greatly appreciated.
Regards,
Steve
Questions:
Regards,
Steve
For 4ohm 86dB magnepans what would be the best power supply configuration?
You should be looking at the Honeybadger's big brother, the Slewmaster. A 5 output pair amp is better suited for the power range you are looking for.
There are no pcb boards available!???
- diyAB Amp The "Honey Badger" build thread
