1. Someones else can reply regarding the max thickness of the heatsink plates.I'm just in the process of getting everything I need for my build as I wait for the boards, but I have a couple questions?
The Aluminum Plate Heatsinks - What Is the max thickness that can fit on the board, as I would like to tap the holes and not use nuts.
Inductor - I have 15awg and 17awg magnet wire on hand, can I use either, or should I order some 16awg?
Resistors - Any thoughts on using YR1 series, or just stick to the BOM.
Thanks!
2. Yes you can use 17awg (1.15mm). I suspect a coil with 15awg (1.45mm) might not fit. Since you have the wire, make one and try.
3. You can use any resistors that you like if they fit. However you need to be careful of the wattage. If it says 1/2W don't use 1/4W.
Hi everyone I hope you’re doing fine. Please i would like to buy some wolverine boards, but don’t who to talk to. Can anyone help ?
Please subscribe to the next group buy. The last one is now closed.
https://www.diyaudio.com/community/threads/diyaudio-wolverine-pre-order.380488/
Thanks, I just didPlease subscribe to the next group buy. The last one is now closed.
Hi Guy's
I have just created a "Wolverine" build thread.
The thread can be found here.
DIY Class A/B Amp The "Wolverine" build thread
This thread is for people to discuss their builds, build issues, and parts for the DIY Class A/B "Wolverine" Power Amplifier.
Ok fine, I just chk back the build guide. Only one type of front-end board be used for EF3-3 & EF3-4,sorry my confusion 😅
Correct, currently there is only one type of IPS (frontend). Since the EF3-4 is longer it could accommodate a longer IPS in the future.
Jeremy
Boards came today. They look great! Thank you Jeremy for the shipping & thank you to all involved in the making of them. Gonna be powered by a 70v 2000va SMPS in a 4U 400mm chassis. Beasty!
Got most parts needed already here but the darn OPS and 992's are back ordered. The 4281's maybe end of the month but the 4303's don't even show a delivery date.
And the build begins!😊
Starting with one small input board.
Took me like 4 hours to measure and match everything and cross and double check values and solder them in. Haven't cleaned the board yet since the initial blank pcb wash, will do the diodes next and give it a good clean then the transistors and another clean before caps etc.
I was the person who wrote the words "cash grab". I did not post again as I did not see any point in it. It's sad how the self-righteous are so quick to condemn, even the wrong people.Your logic is flawed. If this was a commercial venture or a "cash grab" as you put it earlier, why wouldn't they want to sell as many as possible? Why is the GB now closed?
Why do you continue to badger people here? You've been whining and complaining for 3 days now. And nothing has changed. That should tell you the following: even if everything you've said is correct, obviously nobody here cares. So sadly, you'll just have to suffer through this great unjustice. Please stop polluting the thread.
I stick with my opinion that the schematic should be made available. PCB cad files are not included in my opinion, just the schematic.
This is just an opinion tho.
- DIYA store "Wolverine" (Son of Badger) .... suggestions ??
