diy tl speakers with b&w cwm650
B&W CWM650 driver and Vifa D27TG-05-06
Hi, I found two B&W drivers CWM650 and I want to combine them with Vifa D27TG-05-06. This is totaly new for me, I never made loudspeakers. Can U help with box design and suggest the crossover too 🙂 .
Here it is TS parameters for both drivers:
Vifa D27TG-05-06: http://www.d-s-t.com/vifa/data/d27tg-05-06a.htm
Nominal impedance [ohm] 6
Voice coil resistance [ohm] 4.6
Nominal power [W] 100
Short term max power [W] 400
Long term max power [W] 200
Operating power [W] 3.2
Sensitivity [dB] 92
Frequency range [kHz] 2.5-30
Free air resonance [Hz] 1000
Voice coil diameter [mm] 26
Voice coil height [mm] 1.6
Air gap height [mm] 2
Voice coil inductance [mH] -
Eff. diaphragm Area [cm?] 7.1
Moving mass [g] 0.3
Magnet weight [g]/[oz] 240/8.5
Force factor [Bl] 2.7
VAS [l] 0.006
Qms 2.15
Qes 1.19
Qts 0.77
B&W CWM650:
- Mechanical Parameters -
Fs = 74Hz
Qms = 4,653
Vas = 7,558 liters
Cms = 0,332 mm/N
Mms = 13,95 g
Rms = 1,394 kg/s
P-Dia = 127 mm
Sd = 126,7 sq.cm
- Electrical Parameters -
Qes = 0,824
Re = 3,91 Ohm
Le = 0,328 mH
Z = 4 Ohm
BL = 5.547 Tm
Pe = 60 watts
- Electromech. Parameters -
Qts = 0,7
no = 0,358 %
1-W SPL = 87.69 dB
2.83-V SPL = 90.8 dB
Thanks.
ts parameters
Here what i got.Driver is 6,5 inch 130w,8ohm.kevlar membrana.
B&W CWM650:
Fs = 74Hz
Qms = 4,653
Vas = 7,558 liters
Cms = 0,332 mm/N
Mms = 13,95 g
Rms = 1,394 kg/s
P-Dia = 127 mm
Sd = 126,7 sq.cm
Qes = 0,824
Re = 3,91 Ohm
Le = 0,328 mH
Z = 4 Ohm
BL = 5.547 Tm
Pe = 60 watts
Qts = 0,7
no = 0,358 %
1-W SPL = 87.69 dB
Greets!
I'm curious where you found these, all I found in a search was an in-wall speaker with just basic specs. Anyway, these are best suited for a relatively large sealed cab or well stuffed (~aperiodic) TL to mimic an IB. Frankly, considering the high Fs, sticking it in a 1-1.5 ft^3 sealed cab is what I'd do. If you want a TL, then Rick's Alpha TL design tuned to ~104 Hz is as good as any for a ~compact cab:
L = 29.21"
CSA (w x d) = 73.613"^2
Stuff to suit, a sim suggests 36 oz distributed along ~80% of the line or a bit more if a more IB like response is desired.
For sure it's not suitable for a Daline. With no Xmax given, no idea what the excursion limited power might be.
GM
planet10 said:
Nice looking driver (for the yellow kevlar look). Qt is high for any BR enclousre, but the parameters look decent for an alpha TL.
Here is a small spreadsheet GM did for calculating an alpha TL.
dave
Greets!
Oops! I forgot I was supposed to make the spreadsheet more user friendly. Maybe I'll have some time this week. At least it's on my long 'to do' list now.
GM
