DIY SONY VFETS pt 3 - Got VFETs?
LOL…did same google and was surprised and studying over results.
Now just wondering about pin length on transistors being long enough to make it through quarter inch aluminum “T” bar and still seat properly in socket.
I’m assuming I’d have to do a chassis type mounting of the transistors on the extrusions and remote mount OS boards and run wire jumpers to the pins and case of these TO-3 devices?
try to choose sockets looking as having shortest length from surface to pin clamps
then when you get it, you'll know is there enough pin length to leave pcb sandwiched
though, it's best to practice some desoldering, or even better - to buy desoldering station
life is too short to not have best tool for job :clown:
Forgot to mention… as I was thinking and googling at the same time as Mighty ZM was answering and scolding me for being a lazy de-soldering Padawan…
I believe the same type sockets were used to mount TO-3 transistors to the heatsinks in my old Counterpoint SA12
Developed plenty of heat and drew substantial current…nevver an issue with it…and I’m sure countless other Mil-spec applications it seems that the TO-3 sockets have been used in.
I found some nice sturdy looking bakelite versions with gold plate contacts on eBay
Reactions: ra7
Fortunately the performance of the amp is not heavily dependent on the ranking, although it's nice to have left and right matching (audiophile anesthetic). Worst case it's an adjustment.
Papa stated the above in post 77.
I just want to make sure I interpret it correctly…
Matching VFETs help soothe audio nervosa.
It is possible to build these iterations of the VFET amps using unmatched 2sj28, 2sk82, 2sj18 and 2sk60…possibly others…as long as you make adjustments to a few (gate?) resistors?
I ask because I’m considering purchase of unmatched VFETs to keep the 2016 push/pull kit intact to build afterwards.
regarding ranking:
I have unmatched 2SK182. Worse, one has gate current. [Specs say max 1 mA; my case, up to 200micro).
- The biasing differs to get 2.1 A: one channel -6.5V, the other -7.3V. I have the SIT amplifiing, choke in drain.
The result: 0,5 dB difference between channels. My Alps Royal Blue pot also has a channel difference of 0,5 dB. The amp goes flat from 6 Hz to very high. No overshoot what so ever.
This is all totally inaudible.
With the SIT as a source follower there will be maybe < 0,1 dB difference. Moot.
Why matching might be important: if there is feedback and hence risk of current hogging between paralleled devices (e.g. the SONY amps).
difference is in xconductance/internal resistance of SITs, having nothing with biasing voltage
anyway, combine channels in that way, with ALPS - stronger channel getting weaker signal from ALPS
:rofl:
What I did is make a 'balance pot' with a 5k resistor and a 10 k pot that can be turned either way, for that balance. The tube pre-amp itself again has some slight imbalance. [I used to have 300B SE and without NFB it was within 1 dB].
I used to tell meself I could hear the difference on my 1957 Electrostats. Indeed, panning gave a shift of image.
But that imaging was also possible because I had a CD (Meridian) and preamp (lots of 2nd harmonics??) that together gave just that tad of sparkle.
Now I do not hear this Nirvana it anymore (small full-range horn, high WAF). 😢
I just dug up a pair of Tokin 2SK-180.....will the N channel kit work??? thanks for the help
I am exploring a French-style "Némésis" stage with these: with a 100 to 150 ohms/8 ohms transformer. The Némésis with the original 2SK135 was the best amplifier I ever heard - in Paris as built by the designers.
Nelson Pass wrote some words about Jean Hiraga's Némésis too. "The Pass SIT1 improved the [2SK135 Mosfet and . .] SiC based Arch Nemesis design another notch. "
Alazira: Because my speakers are something between 8 and 6 ohms (higher = lower) I opted for now for R1 = =0,82 ohm and R2 = 0,12 ohm. I thought it gives this little bit of boost.
But of course in time I will parallel the 0,82 with some 10 ohms or so and short ot the 0,12 sooner or later to make a real CCS. And get your figures.
But I hope I will keep out of the amplifier. I should put up a sign: KEEP OUT.
