hertz pwede mo ba send sa email ko yung specs ng projector mo? magcacanvass kasi ako dito sa china kung magkano aabutin lahat. paki lagay na lang din ung size ng parts tsaka kung pwede bigyan mo ko ng picture kung paano ayusin pagkasunod sunod yung mga parts na yan. kasi wala akong idea kung pano ayusin eh. tnx a lot!!!
Pls. check out my website. Its all there lahat ng ginamit ko.
http://www.diyprojectorphils.netfirms.com
Found this article about how to get an evenly/uniformly disperse rectangular shape light beam.
http://www.extremetech.com/article2/0,1558,1157682,00.asp
I just don't know if this article has been posted before.
"Another optical task is to concentrate and steer the light from the reflector to the imaging engine. This is also an opportunity to mix the light so that it strikes the imaging engine more uniformly. The light from most lamps will be brighter in the center, gradually diminishing as you move farther from the center. On a rectangular screen, the differences can be noticeable by the time the image gets to the corners. One way to resolve this problem is to use a series of microlenses to integrate the light from the lamp and create a rectangular beam. Another interesting solution is to focus the beam from the lamp on the end of a rectangular rod. This rod may be constructed of polished glass or quartz, or its internal surfaces may be surrounded by highly-reflective mirrors. The light rays bounce multiple times within this light pipe, and emerge from the end as a uniform light beam with a rectangular shape. "
This solves wasted light with circular beam pattern that diyers use.
"Merry Christmas to everybody"
Open up my Basic gude in building a projector. Any comments wil be appreciated.
http://s6.invisionfree.com/diyprojectorphils/index.php?act=idx
Thats fairly old news bud, ive posted that article several times in the last 1.5years. Yess that does help solve the wasted light issue but it also creates other issues such as blured light. It works the same as a pyramid.
Trev🙂
P.S Merry Christmas!!
I will try to do some searching where to buy that rectagular rod and maybe try it if its economical.
You can easily make one out of solid plexi square bar, just polish it well. You will also need an elliptical reflector.
Trev🙂
Has anybody tried this lcd? its very cheap here costing only $125 (7000 pesos).
http://img.alibaba.com/photo/50216670/TFT_LCD_TV__SP_H8001_.jpg
http://groups.msn.com/diyprojection...essage=11465&LastModified=4675506790030979088
resolution, resolution, resolution....
8 Inches
Spot distance: 0.297(horizontal) x 0.297(vertical)mm
FYI, 15" has 0.297x0.297 pixle size. so this one has much lower resolution. it turns out to be a .... VGA!!!
Surprising? wasn't it stated as pixle: Maximum 1024 x 768 ? tricky part is "maximum". It means nothing more than that this monitor CAN take XGA signal. It doesn't mean it can DISPLAY that many pixels. The person who canceled his auction did a right thing. because more cautious way is "maximum resolution". "pixel maximum " might get him into trouble, because people tends to believe it has that many pixels.
But, keep looking, a cheap, small size, XGA is the holy grail of compact DIY projector.
8 Inches
I had the chance to examine its crappy and cheap manual and it says its best for 800x600 resolution and its a real tft-lcd.
If it is svga, then it could be better than my lcd and the price is more than half less than i spend.
You are way and above us Trev. maybe in the near future or maybe 2 years from now where the quality of would be old dlp projector will be exellent. I still can't grasp how are we gonna proceed in improving an old cheap DLP. We have one at the office but the color is crappy.
BTW the HAMI monitor is suitable for diypj.
These guys form diybeamer are really good. ( maybe i eat flowers can translate this link better)
http://translate.google.com/transla...&hl=en&ie=UTF-8&oe=UTF-8&prev=/language_tools
- General Interest
- Everything Else
- The Moving Image
- DIY Projectors
- diy projector from the Philippines
