need help
sir i need 15 inch top speaker seal cabinet design for single and dual speaker and 24 db bass crossover for 18 inch bass reflex enclouser.thanks
C15 mid bass
Hello ....
Hello,
Please, tell us how to setup the limit to 20 W tweeter for this schematic ...
http://www.diyaudio.com/forums/atta...-x-over-mosfet-protect-not-compress-peaks.jpg
http://www.diyaudio.com/forums/pa-systems/174053-diy-pa-speakers-setup-line-array-8.html
what to change as resistor ... caps ... ??
Also ... how to setup this one for 20 W ... ?
http://www.diyaudio.com/forums/atta...-hf-x-over-bjt-protect-not-compress-peaks.jpg
Thank you in advance,
Emil
Hello,
Emil
DIY PA speakers line Array
I have been reading your articles from here and other forums, how is the Quasi double 18 sound and can I use Faital Pro 18" Neodymium? And do you have any plots from other woofers? Thanks🙂
Plots from simulator do not have anything common with real life measurements... You can use Faital Pro 18 in Quasi Horn and you can espect 4-6dB greater SPL from 80 to 150Hz compare to bass reflex.
apex audio can you recommend a nice Faital neo 18" for this Double 18" Quasi horn? With mid Qts. like Qts .31? Thanks!
Horn plan for 12 inch.
Eh I don't mean to be rude but.. What kind of program did you use for THAT?
The panels aren't connected or square drawn, and the measurements aren't put in place properly.
If you can get me some more measurements I can make a flat drawing and 3D view in my V20 version of Solid Edge.
Single 12
Any plans for 1x12 inch + 2x6 inch+ 1x1 inch?
Bass 2x12inch + mid 4x6inch + 2inch HF driver
Detail
Can you give the detail for this plans?
26+26l 12inch bandpass + 8l 8inch midle
- Live Sound
- PA Systems
- DIY PA Speakers Setup (Line Array)
